Author Topic: Inline fuel heaters?  (Read 6603 times)
January 15, 2008, 09:20:37 am
flash319
  • 163
« on: January 15, 2008, 09:20:37 am »
Does anyone have one of these in their cars?  Do they help with starting or just to help pump the fuel?   What brand have you tried?
Reply #1January 15, 2008, 11:03:19 am
  • 1739
« Reply #1 on: January 15, 2008, 11:03:19 am »
unless it's super cold [yellowknife cold] you don't want to heat diesel. i sell vegetherm inline heaters for vegoil systems. i wire them so they only work when using wvo
Reply #2January 15, 2008, 11:07:36 am
flash319
  • 163
« Reply #2 on: January 15, 2008, 11:07:36 am »
So heating the air is better for starting, thus glowplugs?  I have an old Ford tractor that does not have glow plugs and it is in the middle of the bush, so this was sort of an off topic thread.  I was thinking of doing it to both engines though.  I heard somewhere that cummins has some kind of an inline air heater, like a toaster on the intake.  is this true?
Reply #3January 15, 2008, 11:23:55 am
subsonic
  • 1836
« Reply #3 on: January 15, 2008, 11:23:55 am »
Many fuel filters have a built in heater element.  Racor makes great diesel fuel water sperators with the option of a built in fuel heater probe.
Reply #4January 15, 2008, 02:19:55 pm
914turboford
« Reply #4 on: January 15, 2008, 02:19:55 pm »
Ford/Navistar IDI 6.9's (probably 7.3's, also) have a heater in the fuel line. Not sure when it activates. You can find these motors in JY's so if you decide you need one you might consider it.
Brian
Reply #5January 15, 2008, 04:04:21 pm
  • 1739
« Reply #5 on: January 15, 2008, 04:04:21 pm »
fuel line and fuel filter heaters are only for extreme cold, and for tractor trailers which are being driven all day in cold weather. some diesels such as vw's have a small valve in the return line which lets some fuel back into the fuel filter to heat the fuel to a certain extent, but it won't help start the car if the filter is already frozen.normally diesel should not be heated. A4 Tdi's automatics even have fuel coolers.
Reply #6January 16, 2008, 03:08:34 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #6 on: January 16, 2008, 03:08:34 am »
Quote from: "flash319"
Yes, some of the Cummins engines have heaters in the intake passages.  The activation is controlled by the engine ECU based on various temperature sensors in the engine.
As far as heating the fuel, our trucks actually have coolers in the fuel system so that the fuel does not get too hot.  Fuel should be cool for higher density, heating would actually lean out the cylinder air/fuel mixture.
Calvin
91 VW Golf 1.6NA 5spd
Reply #7January 16, 2008, 07:00:17 am
« Reply #7 on: January 16, 2008, 07:00:17 am »
Maybe you could put some peltiers with fins in the intake so you could flick a switch and heat the air when starting. Though people usually think of them relating to cooling, they output 150% more heat than the energy you put into them.
Reply #8January 16, 2008, 03:19:45 pm
bigblockchev
  • 271
« Reply #8 on: January 16, 2008, 03:19:45 pm »
I have an old Onan generator which has glow plugs and air heaters. The air heaters look like a sparkplug with a 1" diameter spring instead of the plug bit on the inside. They would be easy enough to mount in a largish threaded hole in the intake manifold. They are kind of pricy though over $100 from Cummins/Onan. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #9January 16, 2008, 04:11:17 pm
flash319
  • 163
« Reply #9 on: January 16, 2008, 04:11:17 pm »
Don't the TDI's have like 3 glow plogs mounted in a circle on the intake or is it in the coolent?
Reply #10January 16, 2008, 04:31:32 pm
« Reply #10 on: January 16, 2008, 04:31:32 pm »
Coolant.
Reply #11January 16, 2008, 07:41:50 pm
subsonic
  • 1836
« Reply #11 on: January 16, 2008, 07:41:50 pm »
Quote from: "the caveman"
What do you consider extreme cold?  My neck of the woods is going to be around 3 degrees F on and off this week.  Thats 29 degrees below freezing.
So is diesel at it's best for power when it is just above the point where wax crystals will form?
Reply #12January 16, 2008, 08:10:28 pm
westcoaster
« Reply #12 on: January 16, 2008, 08:10:28 pm »
The cummins motor (B 5.9) is a direct injected diesel. It does not have glow plugs for  cold weather starting. It does have grid heater that pre heats the intake air prior to it arriving in the cylinder.
Turn the key on, lights dim as the grid heater cycles. Grid heater shuts off, crank to start. After starting, grid heaters cycle on and off until the engine reaches a certain temp then the grid heaters stop and the motor simply runs on it's own heat. (that's why you'll see a dodge truck's lights dimming and getting brighter as it's warming up)
The cummins cold start is a slick setup. It works quite well when temps get down. The only thing is, it may not work on any thing other than a direct injected diesel....
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #13January 18, 2008, 06:49:54 pm
BlackTieTD
  • 1512
« Reply #13 on: January 18, 2008, 06:49:54 pm »
Quote from: "subsonic"
that's not all that cold. i don't plug in the block heater until it gets down -20C (-4F) and i've never needed a fuel heater or anything like that. (its -24C in yellowknife right now)
Reply #14February 07, 2008, 04:09:09 am
harry_the_face
  • 6
« Reply #14 on: February 07, 2008, 04:09:09 am »
Wouldn't a lean fuel mixture be an advantage for fuel economy, But bad for power?
85 VW Quantum TD
