Author Topic: Audi 5000  (Read 5944 times)
January 13, 2008, 05:32:23 am
dillenger1
  • 777
Audi 5000
« on: January 13, 2008, 05:32:23 am »
does anyone know if the k26 that came off of these is wastegated?Im getting one here in a bit and i didnt see a wastegate.I was wondering if they used a bov or something.
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1January 13, 2008, 07:09:27 am
Audi 5000
« Reply #1 on: January 13, 2008, 07:09:27 am »
Assuming it's a gas engine as I haven't seen any 5000 Diesels here, a gas turbo isn't going to work well on a Diesel as all the ratios are different, or so I've heard.
Reply #2January 13, 2008, 08:07:25 am
spencebm
  • 686
Audi 5000
« Reply #2 on: January 13, 2008, 08:07:25 am »
i know of the turbo diesel version of the gas turbo and i have seen one around here in the junk yards but i don't know about the wastegate, i am assuming it has one
Ben Spencer
Reply #3January 13, 2008, 10:55:24 am
Audi 5000
« Reply #3 on: January 13, 2008, 10:55:24 am »
i seem to recall them having an external wastegate... just remember seeing a pic somewhere on this site.  i think Trev0rbr had the pic...
Reply #4January 13, 2008, 01:03:01 pm
blkboostedtruck
  • 1535
Audi 5000
« Reply #4 on: January 13, 2008, 01:03:01 pm »
I got 5 K26's in the basment and all are without wastgate! some are water cooled and oil fed! and some are just oil fed! but for sure they require a external wastgate! I used one on my gasser caddy witch is a 1.9 stroker motor and it works quite well! but IMHO they are too big for a diesel unless you make a hybrid out of them?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #5January 13, 2008, 04:23:22 pm
dillenger1
  • 777
Audi 5000
« Reply #5 on: January 13, 2008, 04:23:22 pm »
Isnt it just a matter of how much fuel you can throw at it?If i had fuel coming in early via. stiffer intermmidiate spring on a 10mm head.Would that not cut down on spool time?
Reply #6January 13, 2008, 06:17:28 pm
Audi 5000
« Reply #6 on: January 13, 2008, 06:17:28 pm »
Yeah, and you just can't through enough at a big turbo, plus it has more mass to get up to speed.
