Author Topic: Damn, she's dead for now  (Read 5990 times)
January 10, 2008, 01:02:01 pm
madmedix
  • 204
« on: January 10, 2008, 01:02:01 pm »
Pulled out of my driveway to hear a loud "BANG!" when I engaged the clutch to drive away. Engine started revving madly. I shut her down and stopped instantly (doing maybe 3 mph when this happened).
I get out and hmmm....why can I see the front crossmember hanging down? (Driver's side). :shock:
(photo)
I jacked up the crossmember and put a jackstand under her to keep it near level.
So:
1) What is the proper name for this crossmember?
2) Where the hell can I find one? I've called many boneyards without luck, then again, they may not know what I'm lookin' for and will require a personal visit.
3) What grade bolts would you suggest when I fix her up?
4) Any other suggestions solicited.
Cheers,
Andy
'90 TD Jetta
Reply #1January 10, 2008, 02:14:22 pm
  • 1739
« Reply #1 on: January 10, 2008, 02:14:22 pm »
it should called what you said, the front x member. some jobbers may even have it. get new hardware even if you can get the old bolts out; they will be rotten
Reply #2January 10, 2008, 10:24:55 pm
« Reply #2 on: January 10, 2008, 10:24:55 pm »
those are well known for rotting to nothing. Good thing you weren't ripping it up on the highway :shock:
Reply #3January 11, 2008, 03:31:26 am
madmedix
  • 204
« Reply #3 on: January 11, 2008, 03:31:26 am »
True. BTW, anyone have an ETKA that specs the bolt sizes/grades or any funky parts hiding in there?
'90 TD Jetta
Reply #4January 17, 2008, 02:19:13 pm
Baselyne
« Reply #4 on: January 17, 2008, 02:19:13 pm »
must be a mk2
