Author Topic: How to easily identify a 36mm Oil Pump  (Read 3867 times)
January 09, 2008, 02:47:09 pm
Fionn
  • 24
« on: January 09, 2008, 02:47:09 pm »
Hi,
    I have two oil pumps to choose from on my rebuild, both are from late model (86' JP Code, Hydraulic Head) engines. I'm wondering if there's an easy way to tell if they're 36mm or not?
Thanks in advance.
Reply #1January 09, 2008, 07:08:52 pm
CoolAirVw
  • 175
« Reply #1 on: January 09, 2008, 07:08:52 pm »
Quote from: "libbybapa"
Measure the gears... :wink:  :D
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #2January 09, 2008, 07:29:23 pm
Black Smokin' Diesel
  • 656
« Reply #2 on: January 09, 2008, 07:29:23 pm »
86->30mm pumps, 100% sure. VW started to use the 36mm units in late 87 early 88
91 Passat syncro 1.8T swapped.
Reply #3January 10, 2008, 12:46:32 am
Fionn
  • 24
« Reply #3 on: January 10, 2008, 12:46:32 am »
Cool guys, thanks for the replies.
I'll crack them both open to measure for sure. Would a 30mm if that's what I have be considered insufficient to supply both a hydraulic head and additional oil squirters on an originally NA engine?
Reply #4January 10, 2008, 02:19:28 am
dillenger1
  • 777
« Reply #4 on: January 10, 2008, 02:19:28 am »
So you guys are saying if you have a hydrolic head then you have the 36mm?
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #5January 10, 2008, 03:39:27 am
Fionn
  • 24
oil pump
« Reply #5 on: January 10, 2008, 03:39:27 am »
I dont think so, both my blocks are hydraulic (we got very few solid lifter heads here) and that would contradict what BSD has said above.
Reply #6January 11, 2008, 04:42:47 am
somolovitch3
  • 290
« Reply #6 on: January 11, 2008, 04:42:47 am »
Question, when is someone going to measure the outside of the 36 mm pump and compare it to the outside of a 30 mm pump?
When at salvage yard quick and dirty is best! :twisted:
Also, does the style of pick-up tube change with the year or with the size of the gears?
tia
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #7January 11, 2008, 09:13:19 am
« Reply #7 on: January 11, 2008, 09:13:19 am »
Quote from: "somolovitch3"
tia
The 36 mm pump is taller but I dont have one with me at the moment to compair.
I still have a extra 36mm pump just sitting here if someone needs one.
Reply #8January 14, 2008, 03:05:09 am
  • 2932
« Reply #8 on: January 14, 2008, 03:05:09 am »
Measuring the outside of a pump won't tell you anything, in most cases.
 Some of the early pumps used shorter mounting bolts because the pump was so short.
 I have posted on here, somewhere on this forum pictures of a 30mm and 36mm pump side by side.
 edit: found http://vwdiesel.net/phpBB/viewtopic.php?t=7071&postdays=0&postorder=asc&highlight=oil+pump&start=30
Reply #9March 14, 2008, 08:10:50 am
burnt_servo
  • 278
« Reply #9 on: March 14, 2008, 08:10:50 am »
Quote from: "Black Smokin' Diesel"
neither the '88 engine in my car now , or the '90 engine i pulled out had the bigger oil pump .
1990 jetta , tweaked pump , tweaked turbo , ported head  2.5inch exhaust .
1993 dodge w250 , diesel ... removing the dead moose parts .
