Author Topic: connecting rod bolts  (Read 3930 times)
March 26, 2005, 06:44:05 am
jake zak
  • 19
« on: March 26, 2005, 06:44:05 am »
Hi
I think I posted in the wrong forum before...
I hope someone can shine some light on this for me..
I need connecting rod bolts for my 1985 Turbo diesel MF engine that I am overhauling..
book states that there are stretch bolts and should not be reused.....
NOW ..I am trying to get them.BUT all they list is for gas engines and have no info on diesels..
QUESTION...is the connecting rod bolts the same for 1.6 Ltd and the 1.8L gas????
may be someone has gone through this and can saver me time..
thanks
Reply #1September 08, 2011, 03:51:10 pm
myvolkswagen
  • 96
Re: connecting rod bolts
« Reply #1 on: September 08, 2011, 03:51:10 pm »
This is really old but I'd like to know. Dealer said $96 for all of them which is stupid so I bought arp but is there a source for these?
Reply #2September 08, 2011, 04:18:55 pm
« Reply #2 on: September 08, 2011, 04:18:55 pm »
i dont think that these engines got stretch bolts until the late 80s..
i know most of us have been re-using rod bolts for a long time, with no ill effects..
theres a way to tell if they are stretch bolts or not, i just dont remember what it is..
Reply #3September 08, 2011, 06:10:58 pm
410
  • 581
« Reply #3 on: September 08, 2011, 06:10:58 pm »
ID parts sells connecting rod bolts for all tdis with rotary pumps including ahu and iz.  I know the 1.9td engine code aaz also used these bolts but I don't know if they are the same as the 1.6td.  They're listed as 8x1x45mm.  Not cheap at almost six bucks a piece times eight but if it prevents a rod from leaving the engine then they're well worth it.
Reply #4September 08, 2011, 06:21:09 pm
« Reply #4 on: September 08, 2011, 06:21:09 pm »
im almost positive that the 1.9 bolts are different from the 1.6 bolts..
1.9 bolts ARE FOR SURE stretch bolts.. only SOME 1.6's had stretch bolts.. and i think it was only the late 1.6's
Reply #5September 08, 2011, 06:32:18 pm
410
  • 581
« Reply #5 on: September 08, 2011, 06:32:18 pm »
myvolkswagon, or anyone really, can you give us the specs on the 1.6 con rod bolts?  It would be good to know.  I don't have any 1.6's torn down right now.
Reply #6September 08, 2011, 06:39:28 pm
« Reply #6 on: September 08, 2011, 06:39:28 pm »
i can give you specs for the 1.5/early 1.6 rod bolts.. i have a crushed 1.5 rod hanging on my wall..
Reply #7September 08, 2011, 06:57:09 pm
RadoTD
  • 513
    Stage WTF
« Reply #7 on: September 08, 2011, 06:57:09 pm »
The way I've always understood it is that a stretch bolt can't be rated as a 10.9 or 12.9 grade etc as it's a different steel than in those ratings as bolts.
Therefore, if on the head of the bolt, it has a 10.9 or 12.9 stamp, I think it's quite safe to say it's NOT stretch. But, if you can't find either of those grades stamped on, I would assume it is.
When I rebuilt my engine, I put new OEM stretch bolts in, but I'm actually tempted to pull those out and put a 12.9 grade bolt in. That way I actually know how strong the steel is holding them on and I know a 12.9 isn't going to let go at 6000rpm's. I'm probably just paranoid though.
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #8September 08, 2011, 06:58:16 pm
« Reply #8 on: September 08, 2011, 06:58:16 pm »
i put arp bolts in my car... they're cheaper than the oem bolts and better, so why not, and i'm pretty sure the ones i used were the same as for a g60
Reply #9September 08, 2011, 07:08:28 pm
Mark(The Miser)UK
  • 1557
« Reply #9 on: September 08, 2011, 07:08:28 pm »
8)If the head of the conrod bolt is hemispherical, and a 15mm threaded portion, then it is  high tensile.
Conical headed is the later stretch with a 25mm threaded portion 8)
Mark-The-Miser-UK
