Author Topic: hello new guy  (Read 5991 times)
January 08, 2008, 12:10:39 am
TDSami
  • 15
hello new guy
« on: January 08, 2008, 12:10:39 am »
just registered, have done some light searching and decided to join, my rig is in my sig line, heres some build pics
http://www.cardomain.com/ride/2449168/1
im looking now at increasing boost and fuel
88.5 Samurai w/ 84 VW turbo diesel, 2 1/4 exhaust, 31" BFG M/Ts, LockRites, 6.4:1 t/case gears  df/cf clutch
Reply #1January 08, 2008, 12:15:15 am
hello new guy
« Reply #1 on: January 08, 2008, 12:15:15 am »
hmmm the alternator gets so much belt action that way... the normal 1.6TD setups don't have that much so after a while they tend to slip... mine is starting to slip again so i have to re-tighten it.. maybe i should consider some loctite???  :lol:
i also know that manufacturers who put the alt behind there add a fresh air 'scoop' so that the alternator doesn't get heat soaked and cook itself.  any plans to keep it cooler? maybe a bit of a heat shield of some sort?  i would only imagine it being an issue while on a really hot summer day sitting in traffic.
Reply #2January 08, 2008, 12:20:28 am
TDSami
  • 15
hello new guy
« Reply #2 on: January 08, 2008, 12:20:28 am »
im not too worried it is a GM unit and its not real tight to the motor and right in front are 2 10" electric fans, ya it will transfer rad heat to it but theres lots of room there, ill worry if it happens but oh well thats the first design
Reply #3January 08, 2008, 12:26:56 am
hello new guy
« Reply #3 on: January 08, 2008, 12:26:56 am »
Quote from: "TDSami"
i'm more worried now  :lol:
Reply #4January 08, 2008, 12:29:31 am
TDSami
  • 15
hello new guy
« Reply #4 on: January 08, 2008, 12:29:31 am »
ya im not a big gm fan but same amount of wiring as the sami one, basically plugged in, the sami one wouldnt charge enough with everything on even though the alt tested good, id be more scared of the Ford one ive seen them burn even while turned off
Reply #5January 08, 2008, 05:47:41 am
hello new guy
« Reply #5 on: January 08, 2008, 05:47:41 am »
Quote from: "jtanguay"
Yeah, but you can rebuild 10 GM ones for the price of 1 VW alt. :P
Welcome. I think I talked to you in some other forum as I had problems with my belt routed that way, but you had said yours had been fine. I ended up running a ribbed belt for the alt and an idler pulley to tighten the water pump.
Reply #6January 08, 2008, 06:34:19 pm
TDSami
  • 15
hello new guy
« Reply #6 on: January 08, 2008, 06:34:19 pm »
jimfoo im only on a couple sites other than this in Canada, mine doesnt slip as it has lots of bite using about half of each pulley
