Author Topic: ditching a/c  (Read 3372 times)
January 07, 2008, 08:46:47 am
91MF
ditching a/c
« on: January 07, 2008, 08:46:47 am »
so do i need the alternator bracket from a non a/c diesel? what about the alternator pulley?
new to diesel ***ery and wondering what the hell im doing.
Reply #1January 07, 2008, 12:32:53 pm
Baselyne
ditching a/c
« Reply #1 on: January 07, 2008, 12:32:53 pm »
does anyone know what that rad thing is infront of my rad? is that for the AC that used to be in my car?
what's all involved in removing the AC?
Can someone please list all the parts for the above user and myself please!
thanks in advance
Reply #2January 07, 2008, 12:43:13 pm
shegel
  • 312
ditching a/c
« Reply #2 on: January 07, 2008, 12:43:13 pm »
me too
1986 Golf 1.6l non turbo (R.I.P.)
1999.5 jetta (bought with 122145)
1969 karmann ghia(diesel swap dream)(most likely going to be subaru powered)
1998 jetta tdi (parents car)
Reply #3January 07, 2008, 02:34:55 pm
ditching a/c
« Reply #3 on: January 07, 2008, 02:34:55 pm »
That thing in front of your rad is the condensor used for the A/C.
If you have removed all the stuff you can remove it.
You need a non A/C bracket if you are going to run it with out the compressor now.
I may have one but I wont be able to check till tomorrow or the weekend.
Reply #4January 07, 2008, 02:58:41 pm
ditching a/c
« Reply #4 on: January 07, 2008, 02:58:41 pm »
It depends on what generation of vehicle you have.
Mk3s Don't require any new brackets that I'm aware of, just a smaller belt.
Mk2s don't require the actual bracket to be replaced, only the alt and the "arms" that allow for adjustability between the bracket and the alternator.
Another option for the mk2 is to just delete the compressor and then get a different pulley and run a really long belt. This isn't recommended though
MK1s I'm not sure as I've never seen a AC setup
Basically pull whatever is connected to the AC out. Make sure that the rad fan still works. Depending on how it's wired for your year car with the AC shiz ripped out the fan might not come on at all
Reply #5January 08, 2008, 04:25:44 am
rattler
  • 8
ditching a/c
« Reply #5 on: January 08, 2008, 04:25:44 am »
When my 90amp altenator in my 91 finally went I removed the AC compressor and found I had to go to a 60amp altenator due to the bracket setup as I did not have the proper adjuster to tension the 90amp altenator without the compressor pulley in the mix. The 60amp altenator is above the pivot and the 90 amp is below (as far as I can remember) this caused serious issues.
I am having a hard time keeping belt tension with my setup and really miss the 90amp altenator. I may try to adapt a tenstioner pulley from a newer model with serpentine belt to work with the v belt and see if that will keep the belt from slipping.
I have not had any issues with fan operation, however I left all the original wiring where it was. I have yet to replace the air selector with the non-ac one but there is wiring attached to it as well to control the fan operation on the A2.
JR
Reply #6January 08, 2008, 08:19:43 am
Baselyne
Luckly for me...
« Reply #6 on: January 08, 2008, 08:19:43 am »
Oh my 80 diesel there was A/C but when the compressor was removed there was no need to replace any mounting brackets
Just needed a shorter belt... maybe some others had to change the bracket? So check into your bay because I know some freinds had to...
I guess it depends on the model or? So many small details...
Reply #7January 08, 2008, 09:39:45 am
TedV
  • 182
ditching a/c
« Reply #7 on: January 08, 2008, 09:39:45 am »
Quote from: "burn_your_money"
my 84 Rabbit diesel was a non A/C car.  the non air bracket is lost in my parts piles.  on a search and rescue mission now, but no luck finding yet.
Reply #8January 08, 2008, 11:55:04 am
shegel
  • 312
ditching a/c
« Reply #8 on: January 08, 2008, 11:55:04 am »
you can use a switch(more work though) or wire in an automatic switch they have them at schucks
Reply #9January 28, 2008, 07:09:28 am
Baselyne
ditching a/c
« Reply #9 on: January 28, 2008, 07:09:28 am »
Ive been told this isnt the way to go.... Anyone had a switch wired into there rad fan and forgot about turning it on?
 Ive heard of freinds blowing out there hoses because they forgot that shiz
So in removing the A/c you just need to pull everything that connects to the condensor....What do these tubes lead to that go into the firewall from the engine bay? A/c related tubes....of some sort!
Reply #10January 28, 2008, 11:41:09 am
BejamminR
  • 89
ditching a/c
« Reply #10 on: January 28, 2008, 11:41:09 am »
Tell you what, I'll likely take everything you don't need for the A/C, because I am doing the reverse of what you are.  :lol:
I've got a '95 Jetta body with a 2.0L ABA gas engine and an auto transmission that I'm going to be putting my '94 AAZ with a 5-speed in. The transplant body already has AC, so I just need the additional brackets and stuff as well as the AC-model serpentine belt to drive it.
PM me - I won't be doing the swap for another couple of months, so I'm not likely able to give you the missing parts in a timeframe that works for you, but I'll want to buy or trade for the brackets and stuff for my own swap. Thanks!
Reply #11January 28, 2008, 11:53:25 am
duffer
  • 164
ditching a/c
« Reply #11 on: January 28, 2008, 11:53:25 am »
The pipes that go through the firewall,
  on the passenger side, go to the heater
  box. Inside the heater box is the
  evaporator (I think it's called). It looks
  like a small rad. (about 8" X 9" or something).
  You can just cut those pipes off, but you'd
  probably be better to just look for a non a/c
  heater box and replace the one in the car.
  If you remove the a/c heater box, you'll
  find a drain pipe underneath it around the
  middle of the "hump".
  You can pull out the plastic pipe and plug
  the hole. Otherwise vast numbers of mice
  will get into your car and abscond to Mexico
  with it.
Reply #12January 28, 2008, 06:27:32 pm
jasonsansfleece
  • 162
ditching a/c
« Reply #12 on: January 28, 2008, 06:27:32 pm »
I've removed two AC systems. I used 60 amp alternators on the existing bracket because its the easiest way to go ( especially if you have parts cars :D )
 You can use the 90 amp alt if you fabricate a tensioning arm.
I used a pair of bolt croppers and cut the tubes and pipes where ever to facilitate easy removal. As far as the pipes through the fire wall, cut them close to the fitting and forget about it .
In both cases the only issue I had with the radiator fan was the fact it would switch on if the heat selector lever was in an AC position. Probably what its supposed to do but one last niggling vestige!
Guy
Reply #13January 29, 2008, 05:00:40 am
rattler
  • 8
ditching a/c
« Reply #13 on: January 29, 2008, 05:00:40 am »
BTW - If you want a fan switch ond/or indicator light, here is a basic description of the circuit...
http://www.4crawler.com/Diesel/CheapTricks/RadiatorFan.shtml
