Author Topic: Fixing my fuel lines- How do I purge the air out of the line  (Read 4074 times)
January 05, 2008, 11:52:00 am
mtnbob
  • 738
« on: January 05, 2008, 11:52:00 am »
I am repairing the splits in the two fuel lines under my car. Once I get them repaired, do I need do do anything special to get the air out of the lines? They have completely drained of diesel.
Thanks,
Robert
96 Subaru Outback Wagon
Reply #1January 05, 2008, 12:09:14 pm
« Reply #1 on: January 05, 2008, 12:09:14 pm »
As long as the fuel filter is full you should be ok. You'll probably notice some power loss as the lines work themselves clear of air
Reply #2January 05, 2008, 12:12:08 pm
mtnbob
  • 738
« Reply #2 on: January 05, 2008, 12:12:08 pm »
thanks for the quick answer. the weather is looking good outside for once in a few weeks, and i'm heading out to finish it up. 8)  54 degrees F and sunny :D
Reply #3January 06, 2008, 05:44:09 pm
blkboostedtruck
  • 1535
« Reply #3 on: January 06, 2008, 05:44:09 pm »
I have a outboard boat gas bulb primer installed after the filter and before the I.P. works great! cheap too! and it will tell me if i have blockage or i need a fuel filter change it will collaps when the engine is running!
so i highly recomend one for everyone!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
