Author Topic: crank oil gallery plugs  (Read 2504 times)
January 02, 2008, 04:55:41 am
moTthediesel
  • 194
« on: January 02, 2008, 04:55:41 am »
I'm rebuilding a 1.6 TD Quantum motor. Engine had about 170k miles on it. Internally it looks pretty good, the usual chunked intermediate shaft bearings, but otherwise OK.
Do you think it is worthwhile to drill out the oil gallery plugs in the crank to clean out the passages? If so, what's the best way to replug them?
moT
'82 LandCruiser Diesel Conversion
4Cylinder 3B/KKKturbo/AudiIntercooler(gone, BNF)
'92 Dodge/Cummins D350 Getrag Dually
356 w/Quantum 1.6TD (73 mpg!)
'85 BMW 524td (Der Komisar)
'00 Jetta TDI 5spd
Reply #1January 02, 2008, 12:39:41 pm
bert
  • 423
« Reply #1 on: January 02, 2008, 12:39:41 pm »
Fill the gallery with brake cleaner solvent,leave to soak,then airline them out,redo this until clean solvent comes out,job done  :wink:
Bert
Reply #2January 02, 2008, 03:18:34 pm
somolovitch3
  • 290
« Reply #2 on: January 02, 2008, 03:18:34 pm »
Since you asked...... :twisted:
Drill, punch the little egg-suckers out. use carb cleaner, breake cleaner, whatever, air hose to remove all the gunk et all.
Drill and tap for a socket head plug. Install same with some nice Lok-Tite type substance.
Done!! :roll:
Pour self beers :wink:
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #3January 02, 2008, 05:34:20 pm
bigblockchev
  • 271
cleaning oil galleries
« Reply #3 on: January 02, 2008, 05:34:20 pm »
There are some really long bottle style brushes available for cleaning out the oil galleries. Try your local speed shop for these. I'm not sure I would remove the plugs unless I suspected some kind of abrasive contamination had gotten into the oil passages. I probably would just rinse with solvent, brake cleaner and blow out with an air hose. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #4January 02, 2008, 07:23:55 pm
CoolAirVw
  • 175
« Reply #4 on: January 02, 2008, 07:23:55 pm »
Those plugs cost just a few cents apeice from the dealer.
Take them out, clean and get new ones.  Order extra so you have them for the next motor or for your freinds or in case you mess on up on install.
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
