Author Topic: Drive shafts  (Read 1962 times)
December 31, 2007, 10:49:54 am
gtigadge
  • 14
Drive shafts
« on: December 31, 2007, 10:49:54 am »
Probs the wrong section but after stripping my MF engined 16TD apart after suspected transmission failure (turns out the RH inner drive shaft CV is completely gone) I need some quick info on replacements.
I have been told two different things leaving me clueless, even more so than normal :shock:   One statement is that all the MK2 golf driveshafts are the same and the other that the spline size going into the hub is different for say mine to a GTI.
What shafts are interchangeable if any.  Car is MF engined as stated earlier, UK RHD 1990 mk2 golf so looking for a (drivers,UK) USA passenger side driveshaft, the fat long one  :D
Cheers
Gadge
Everything in life is acceptable in moderation?  Yeah right, just wait until the wife finds out!!
Reply #1December 31, 2007, 11:00:33 am
bert
  • 423
Drive shafts
« Reply #1 on: December 31, 2007, 11:00:33 am »
Hi,there are 2 types as far as im aware,a 90mm and a 100mm inner joint,just measure your old one and replace with the same,
Bert
Reply #2December 31, 2007, 11:29:27 pm
gtigadge
  • 14
Drive shafts
« Reply #2 on: December 31, 2007, 11:29:27 pm »
Good enough for me mate, will do.  It was the splined drive to the hub I was unsure of aswell but should be easy enough to sort :D
