Author Topic: 96 Jetta w/ AAZ ***EDIT: $2000 in Montreal Jan 11-12***  (Read 5843 times)
December 31, 2007, 06:34:51 am
addautomotive
« on: December 31, 2007, 06:34:51 am »
There are a couple cars that I'm looking at, and in the next month or so I expect to put my 96 Jetta up for sale. I am going to post a painfully accurate description, and maybe youze can help me land on a fair price.
The car passed its safety inspection a month ago. I don't let my cars "sneak through" either, I ask them to be rigorous because my wife drives this car A LOT, ie 4-500 kms/wk.
BASICS:
-96 Jetta
-3rd owner
~420k (odometer was changed and shows 240k)
-cruise
-no air, no sunroof
-summer tires, on rims (aluminum 8 spokes) = fair
-winter tires, on rims (snowflakes) = great, 2 studded
-converted to run canola oil (two tank, clean install)
THE GOOD
-Good looking car, "Suede Silver" with blacked out trim + tinted rear windows + roof rack
-Great highway car, with do 140km/hr all day long.
-Recent brakes (pads, rotors, front rubber lines)
-Gas struts all the way around within the past year
-all front bushings within the past year
-front bearings within the past year
-2.25" exhaust from cat (made with "crinkle bend" sections, so not pretty)
-brand new starter, brand new glow plugs, 1 year old 850 CCA battery. This car starts WITHOUT HESITATION, even at -25*C
-glow plugs individually wired, so easy to test
-T3 turbo
-GTD injectors
-EGT Guage
-0.71 5th... 120km/hr =3k rpms
-Very reliable, clean vegoil conversion: Vegtherm, hose on hose, 58 liter steel tank. Has 100+ k of summer + winter driving on vegetable oil, including many trips to Montreal
The Bad
-Cosmetically, getting a bit tatty. Some touch up done, not a perfect match. Minor scrapes & dings. Rear seat bottom doesn't match top. (long story...)
-Using oil. About 1 liter/1500k. Not severe but you have to keep an eye on it. A bit of smoke on startup, I suspect it's the valve seals, and the turbo is a bit oily so I think it's getting sucked through there too. Dribbles some oil past the rear main seal, but no significant oil leaks. It starts like a champ in -25*, so it's not a worn out, wheezy engine.
-Some underbody rust, although it just coasted through its yearly inspection. Expect to do a bit of welding around the rockers for its next safety inspections.
-Transmission shifts rough, noticeably 1st & 2nd. It definately needs a shift bushing kit & adjustment, but I wouldn't want to guarantee that would clear up the problem. Reverse idler was already replaced due to "clicky" reverse issues, and taller 5th was installed.
Some pics:
this isn't a great picture, but it shows the trim, wheels etc. Rood rack included
before trim was blacked out (shows winter rims)
Pics of the veggie conversion here:
http://www.jakepalmeristheman.com/2005/02/feb-12th.html
Am I off my rocker to think it's worth ~3500?
Now, here's a possibility: A couple of the cars I'm considering are in the Toronto area, a couple are in Quebec. Dpending on where I buy a car, I COULD deliver this one when I go to pick up the new one.
Reply #1December 31, 2007, 11:50:18 am
bigblockchev
  • 271
« Reply #1 on: December 31, 2007, 11:50:18 am »
I think that you are in the ballpark for an asking price. The things that would be potential issues for me would be the high kms and the bits of rust. Can't fix either easily, cheaply, or maybe at all. If the car were a no rust west coast car with  200-250 km it would be in the $5000 - 5500 range. but for $2000 diff you couldn't change yours into that. The vegi system is a plus but most people would not want to have to deal with it. It's like a house with a swimming pool , limited market. Here on the west coast you would probably get $4000 as prices are higher here. Just my 2 cents worth. Cheers Dan
it's always something simple
87 Mercedes 190D 2.5 Turbo
2000 Jetta TDI
76 Onan  MDJF 15Kw genset
Reply #2December 31, 2007, 01:58:02 pm
blkboostedtruck
  • 1535
« Reply #2 on: December 31, 2007, 01:58:02 pm »
if you got those axel's off the roof and have them installed on it to where it's all wheel drive i would be interested? :lol:  just kidding i use my rabbit like a truck so i don't use my truck! good luck with the sale! i just had to make a funny? did you laugh?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3January 03, 2008, 08:09:09 pm
addautomotive
« Reply #3 on: January 03, 2008, 08:09:09 pm »
ya, I laughed! :wink:
Looks like I have a line on a car in Montreal, and the deal could close in a week or so.
If anyone in Montreal was interested in this Jetta, I would entertain some lowball offers just to make my life easy.
Reply #4January 05, 2008, 07:58:54 am
addautomotive
« Reply #4 on: January 05, 2008, 07:58:54 am »
Bump.
It looks like I will be in Montreal on Friday to pick up a new car. If anyone up there is interested, I'll sell this car for 2k if they can take it on Jan 11-12. It would save me a flight and a whole lot of hassle.
If anyone is interested, PM me ASAP. I will take a ton of tell-all, no-bull$hit pictures.
Reply #5January 05, 2008, 09:44:52 am
« Reply #5 on: January 05, 2008, 09:44:52 am »
If you could send me pictures that would be great raging_freestyler at hotmail.com
My brother might be interested
Reply #6January 05, 2008, 12:55:19 pm
addautomotive
« Reply #6 on: January 05, 2008, 12:55:19 pm »
will send some tonight. Have to go to crappy tire to get a starter for the samurai
Reply #7January 06, 2008, 07:19:54 pm
addautomotive
« Reply #7 on: January 06, 2008, 07:19:54 pm »
**sale pending**
Reply #8January 07, 2008, 09:10:57 pm
addautomotive
« Reply #8 on: January 07, 2008, 09:10:57 pm »
Sold! Thanks Burn_Your_Money!
Reply #9January 07, 2008, 10:20:09 pm
« Reply #9 on: January 07, 2008, 10:20:09 pm »
Tyler you dog... great score !!
Reply #10January 08, 2008, 04:32:39 am
« Reply #10 on: January 08, 2008, 04:32:39 am »
It's not mine but my youngest brothers
The car now safely resides in the driveway next to the diesel chevette from Alberta. You'd think there were no cars in Ontario :lol:
