Author Topic: A/C wiring  (Read 6725 times)
December 29, 2007, 03:29:57 am
Zulfiqar
  • 254
A/C wiring
« on: December 29, 2007, 03:29:57 am »
I want to wire the high temp cutout switch located in the front coolant flange to make the entire thing operate like VW intended, I know its for A/C as it states 107 degrees C, The A/C harness from the cabin has 3 wires in it,
1X red  - batt
1Xwhite/red going to connector to front of car - Cut from middle of harness underbattery
1Xgreen/white - going to AC comp and also spliced into rad fan with a diode (mech shop did it)
I have this VW wiring diagram but it shows different wire colours.
Anyone chime in because the wires to the 2 pin switch are not in any harness
And while at it what relay is the A/C high temp cutoff relay
Diesel IS the future
Reply #1December 29, 2007, 03:46:29 am
Ziptar
  • 565
A/C wiring
« Reply #1 on: December 29, 2007, 03:46:29 am »
What year and model car??
Reply #2December 29, 2007, 05:42:48 am
Zulfiqar
  • 254
A/C wiring
« Reply #2 on: December 29, 2007, 05:42:48 am »
1986 golfC 1.6 NA (with factory AC)
Reply #3December 31, 2007, 04:42:01 am
Zulfiqar
  • 254
A/C wiring
« Reply #3 on: December 31, 2007, 04:42:01 am »
Anyone???
Can someone walk me through this A/C wiring schematic, like where would I find the A/C high pressure switch wire for the high speed relay. (Ive ghetto rigged it by running an additional wire to it.
Reply #4December 31, 2007, 10:07:39 am
A/C wiring
« Reply #4 on: December 31, 2007, 10:07:39 am »
the high speed switch should be located on the high pressure hose going to the condensor.  there's a high temp switch and a low pressure switch.  compressor will not run on low pressure, and the high temp switch kicks the rad van into high speed mode.
is that what you mean?
Reply #5December 31, 2007, 10:21:34 am
Zulfiqar
  • 254
A/C wiring
« Reply #5 on: December 31, 2007, 10:21:34 am »
OK - figured that out so far, and Ive placed the missing high speed fan relay on the inner fender with a self tapping screw
Theres another switch on the coolant flange in front of the head btw #4 and #3 cylinders, its 2 pins, I couldnt find any wires to connect it to, the wiring schematic I have shows that I should be connecting a wire and a ground to it. It goes to the A/C cutout relay (solidstate), which I cant find at all anywhere. Should this relay be something in the engine room or the relay panel under the dash.
Reply #6December 31, 2007, 04:25:41 pm
A/C wiring
« Reply #6 on: December 31, 2007, 04:25:41 pm »
Quote from: "Zulfiqar"
for the coolant flange in front of the head if i'm nto mistaken thats the temp sender.  it could also be the afterrun switch though..
Reply #7December 31, 2007, 11:25:56 pm
Zulfiqar
  • 254
A/C wiring
« Reply #7 on: December 31, 2007, 11:25:56 pm »
the coolant flange in the front of the head has the temp sender unit also and a large two pin switch which is a NO switch, Ive asked around and it definitely is the A/C cutoff switch for factory A/C cars
Reply #8January 01, 2008, 12:53:15 am
A/C wiring
« Reply #8 on: January 01, 2008, 12:53:15 am »
oh yea in case of the coolant getting too hot because of the a/c system
Reply #9January 01, 2008, 07:44:15 am
Zulfiqar
  • 254
A/C wiring
« Reply #9 on: January 01, 2008, 07:44:15 am »
found the switch wires, they were neatly tucked in the harness beside the battery by the nutjob who previously messed the wiring, its  grn/wht and brn going to relay # 43 on fuse panel.
also found the original red pwr wire for the rad fan and h/speed relay- now still looking for the high speed trigger wire blk/yel it doesnt seem to exist,
is it a direct connection from the switch from the high pressure metal hose resting on the fan shroud considering its so near the relay
