Author Topic: To all you shiny part guys!!  (Read 7689 times)
December 27, 2007, 04:31:07 am
dillenger1
  • 777
« on: December 27, 2007, 04:31:07 am »
So how do you do it?Do you dip them,wash them,what is it .let me in on the seceret.Ive called some places about dipping in the hottank,and its not cheap.$50.00 a pop.So was just wondering if you could post your technique.
thanks,Ben
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #1December 27, 2007, 05:55:00 am
Ziptar
  • 565
« Reply #1 on: December 27, 2007, 05:55:00 am »
I use a product called "Elbow Grease", bulk quantities.    :wink:
Reply #2December 27, 2007, 07:31:03 am
Baselyne
Paint techniques
« Reply #2 on: December 27, 2007, 07:31:03 am »
I actully use this product after I do all the grinding, sanding, wire brushing and angle grinder with brass wheel on...wear safty goggles!~
then its prepped I rub light grade sand paper by hand till its a uniform surface, Then with rubber gloves I apply (not this exact product but i didnt see it on duplicolour's site
http://www.duplicolor.com/products/prepwipe.html
you need to remove all un wanted dirt as paint will just flake off
Ive been painting houses,metal work and industrial for the last 10 years and in my personal experiences ive come to trust a product like above....
Im sure its the same stuff, I just get it in bulk instead how they have it there.... but dupli colours expensive sometimes...
There discription is: A handy, disposable wipe that prepares surfaces to be repaired or painted. Removes grease, wax and solvents that prevent paint from forming a lasting bond. Use it on bare metal, OEM surfaces, aluminum, plastic and fiberglass. Wipe measures 8’ x 10”.
 which should give you an idea of what its going to take to get a nice shiny coat of paint on anything.....anywhere!
Hope that helps....just practice on something
Reply #3December 27, 2007, 07:39:39 am
stewardc
« Reply #3 on: December 27, 2007, 07:39:39 am »
My old valve cover was powdercoated after much sanding.
Reply #4December 27, 2007, 08:17:38 am
Baselyne
« Reply #4 on: December 27, 2007, 08:17:38 am »
ok well some of us arent that good... You just put my painters hand to shame..
 Perfection...Absolute....amazing!~
Some might say...."And then theres powdercoat!"
What model and year's those valve covers coming on? I was told it has something to do with G-60's or....
thanks for making me want to go practice to touch up on my paint skills... but I suppose if I never painted anything like that in 10 years im a lostcoz
Reply #5December 27, 2007, 12:56:06 pm
dillenger1
  • 777
« Reply #5 on: December 27, 2007, 12:56:06 pm »
yes,that truly is beauitful.i dgrease brush,pressure wash if i can then buff on  a wheel or with wire brush.Im about to do my transmission,and i wanted to see if there were any good hints,Do you guys think it would be durable to paint the tranny?Im almost feeling the raw aluminum! :P But i susspose that i could get away with a silver paint,but i also could polish it.i dont know .It seems the paint will  not stand the test of time.
Reply #6December 27, 2007, 01:05:55 pm
« Reply #6 on: December 27, 2007, 01:05:55 pm »
get a sand blasting cabinet from princess auto and go nuts.  thats the quickest and easiest way to clean up dirty old parts.  makes aluminum shiny too
Reply #7December 27, 2007, 02:11:35 pm
« Reply #7 on: December 27, 2007, 02:11:35 pm »
Quote from: "jtanguay"
10X... they go on sale all the time, and can handle just about anything this side of a tranny... in fact you could use the gun to do a tranny.   Perfect for IP pumps, brake calipers, suspension parts....  and the silica sand is cheap too.
'Course, now I need a bigger compressor....   ;-)
Reply #8December 27, 2007, 06:42:32 pm
dillenger1
  • 777
« Reply #8 on: December 27, 2007, 06:42:32 pm »
Yah but im weary of putting things like injection pumps in the blaster.We have one ,imm afraid some sand will get left behind and get in a fuel line or oil,or something,it just scares me.
Reply #9December 27, 2007, 09:43:30 pm
« Reply #9 on: December 27, 2007, 09:43:30 pm »
Quote from: "dillenger1"
thats why you only blast the pump when it is all sealed up. best idea is to just leave some hose connected and seal it all up.  then blast it all up, then you can open the pump and re-seal it etc.
Reply #10December 28, 2007, 03:04:16 am
stewardc
« Reply #10 on: December 28, 2007, 03:04:16 am »
Then you give your Giles pump a nice coat of stealth black.
Reply #11December 28, 2007, 03:09:28 am
stewardc
« Reply #11 on: December 28, 2007, 03:09:28 am »
[quote="Baselyne"
[/quote]
Yes, that's a G60 valve cover. I got it from this site, I believe. It was painted red at the time and I stripped and polished it before powdercoat.
Reply #12December 28, 2007, 06:57:15 am
Baselyne
« Reply #12 on: December 28, 2007, 06:57:15 am »
Yeah everyone send all there rusty parts to stewart C, His two examples of painting show proof of experience
You dont paint intrikat places like on the injection pump without practice and hours of prep.
That idea about the sandblasting kit is great, I was at P.auto yesterday and looking at those... although my compressors a piece..
thanks for the mention on the G-60 cover. I think those look twice is nice as the stock 1.6 ones....just IMO
cheers
Reply #13December 28, 2007, 07:04:39 am
stewardc
« Reply #13 on: December 28, 2007, 07:04:39 am »
The G60 cover is cast aluminum. Be sure to convert to the new-style rubber gasket and studs when installing.
Reply #14December 28, 2007, 05:39:55 pm
dillenger1
  • 777
« Reply #14 on: December 28, 2007, 05:39:55 pm »
Now ive already got my pump apart to reseal.Im also upping to a 10mm pump,im shimming the gov spring,and turning up contol cone.So after all this will it be safe in there ,or will that ruin the new seals?here it is,well thats the lda im using.I decided it would be easier to convert my na pump instead of using the peugot.Its got a two hole belt side instead of a three.It wouldnt of been that hard ,but i also took in to factor that the vw pump was alot cleanerhttp://i249.photobucket.com/albums/gg206/2253benjamin/volkswagendiesel055.jpg
