Author Topic: mk2 manifold clips  (Read 4988 times)
March 22, 2005, 06:08:09 pm
fillmore
  • 60
    • http://fillmorenorthband.tripod.com
mk2 manifold clips
« on: March 22, 2005, 06:08:09 pm »
hey guys, just wondering how to get the spring clamps that are shaped like C's back on my exsaust/ manifold. ive heard that they are hard to get back on unless you have the tool that the dealers use. has anyone ever ran into this problem before? is there a way to get them back on?
Reply #1March 23, 2005, 06:07:45 am
racer_x
  • 123
Re: mk2 manifold clips
« Reply #1 on: March 23, 2005, 06:07:45 am »
Get a 2" U bolt type exhaust clamp. Remove the nuts and pull the "saddle" piece off. thread the nuts all the way down the clamp. Put the "saddle" piece back on upside down (curved part facing outward). Insert this in the spring clamp and "loosen" the nuts on the U-bolt (one or two turns one each side, alternating back and forth) to press the spring clip out. Slip the clamp over the manifold/downpipe joint. Then "tighten" the u-bolt nuts to release the tension and allow the spring clamp to do it's job.
Reply #2May 29, 2005, 10:43:41 am
Wingaman
  • 7363
    • http://www.dmfdiesel.com
mk2 manifold clips
« Reply #2 on: May 29, 2005, 10:43:41 am »
Or make a tool like i did.
371-B, Ch. Ste-Marie
Ste-Marthe QC J0P 1W0
Reply #3June 02, 2005, 08:00:21 am
veeman
  • 421
mk2 manifold clips
« Reply #3 on: June 02, 2005, 08:00:21 am »
Just an illustration to back up what Racer_X said (not my photo, by the way).  Works just fine.  I did this about a month ago...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
