Author Topic: Christmas Eve and Christmas Day teardown!  (Read 5947 times)
December 25, 2007, 06:12:34 pm
Baselyne
« on: December 25, 2007, 06:12:34 pm »
I spent Christmas Eve and Christmas Day tearing down a new to me turbo motor...Some fun pics
The Crane:
The Parts:
The clean as I could get it in few hours while the wify stuffed/cooked the turkey....TD Motor that has me stumped! Please help...
Can someone with the eye of the tiger help me figure this rusty blok code out
Reply #1December 25, 2007, 06:38:37 pm
« Reply #1 on: December 25, 2007, 06:38:37 pm »
Take fine sandpaper to it and the numbers will show up much better.
Reply #2December 25, 2007, 06:38:54 pm
Powjetta
  • 152
    San Diego CA
« Reply #2 on: December 25, 2007, 06:38:54 pm »
I think the numbers you need are on the boss up next to the head, kind of under that glow plug connector.  Try a little sandpaper lightly up there and see if anything shows.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #3December 26, 2007, 05:01:31 pm
Patrick
  • 1034
« Reply #3 on: December 26, 2007, 05:01:31 pm »
The clutch looks like an AAZ........turbo looks like it might be a k14.......not sure about the ip.
Valve cover is old school though. Maybe a mix and match? Does teh intake manifold have a blowoff valve? Does the oil return for the tubo go to the pan or the block?
Reply #4December 26, 2007, 07:58:35 pm
« Reply #4 on: December 26, 2007, 07:58:35 pm »
The oil fitler flange area looks like a 1.6 more then a 1.9. That turbo is too big to be a K14, I'd say K24. I don't see anything strange about the valve cover?
Reply #5December 27, 2007, 01:29:22 am
935racer
« Reply #5 on: December 27, 2007, 01:29:22 am »
Its a MF, 1.6 td with hydraulic lifters. Valve cover is stock, turbo is a k24, oil drain should go the pan, clutch looks like it is a 210mm unit.
Reply #6December 27, 2007, 03:04:57 am
Patrick
  • 1034
« Reply #6 on: December 27, 2007, 03:04:57 am »
Quote from: "burn_your_money"
I thought the clutch and the turbo looked like the newer stuff,(1.9) and the valve cover was 1.6.... maybe the whole head for that matter, the injectors look like 1.6 material...... Wondered if the bottom was 1.9. As for what turbo it is, my eyes ain't what they used to be! :)  :roll:  :) I guess I was looking at the size of the exit hole, not the size of the whole thing.
Reply #7December 29, 2007, 12:34:25 am
935racer
« Reply #7 on: December 29, 2007, 12:34:25 am »
The water pump area doesn't look right for a 1.9 bottom end, it will say on the back wether its a 1.9 or 1.6 in big letters. Or as already mentioned engine code or if there is an oil return in the block or not.
