Author Topic: 1.9 TD real power  (Read 6241 times)
December 25, 2007, 07:29:00 am
flash319
  • 163
1.9 TD real power
« on: December 25, 2007, 07:29:00 am »
What should I expect from a 1.9L TD (IDI) power wise?  If I fuel it up what sort of HP would I see?  Could I see 110+ HP with pump mods and intercooler?  180 lb/f torque?  Realalistic numbers not BS.
Reply #1December 25, 2007, 01:23:55 pm
haybayian
  • 155
Re: 1.9 TD real power
« Reply #1 on: December 25, 2007, 01:23:55 pm »
Quote from: "flash319"
The AAZ is rated 78 HP by the manufacturer and I believe about 100 lbs/ft torque. I was told by the shop that modified my IP that I should expect a 20 HP gain. I am going to run an intercooler , performance air filter, as well as a larger exhaust line. My hope is to crank between 100 and 110 HP. But I may be BS myself. I would like to hear from others.
Haybayian
Keep it simple if you can.
Reply #2December 25, 2007, 04:06:01 pm
bert
  • 423
1.9 TD real power
« Reply #2 on: December 25, 2007, 04:06:01 pm »
My AAZ is unbelievably rapid,i dont know any figures yet but wow what a performer,all i have done is used a T3 from a 1.6TD and fitted a rover 220TD aneroid pin,and a 2.5" exhaust,im well happy with it,no intercooler either,i run at 11psi full chat.Hope this helps
Bert
Reply #3December 25, 2007, 09:13:57 pm
vanagonturbo
  • 639
    • Fine Tuning
1.9 TD real power
« Reply #3 on: December 25, 2007, 09:13:57 pm »
I dont think getting 180 ft lbs will be very feasible for a DD. Not to hard to acheive but also hard on the engine. I might also point out that my experience at this point pertains to my 5k lb Syncro vanagon with an AAZ.
Reply #4December 26, 2007, 03:09:00 am
carrizog60
  • 978
1.9 TD real power
« Reply #4 on: December 26, 2007, 03:09:00 am »
1.6d converted to td:
boost pin reshaped,merc 220cdi intercooler,increased fuel in pump,merc dn261 nozzles,blocked WG with kkk24 running 30psi=136hp at the flywheel.
so you can see 110hp ate pretty easy to achieve.
Portugal
Reply #5December 26, 2007, 03:21:28 am
MJF
  • 581
1.9 TD real power
« Reply #5 on: December 26, 2007, 03:21:28 am »
Quote from: "carrizog60"
Why so much boost? You could get that much power with half that boost. Itīs just stressing the motor :roll:
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6December 26, 2007, 04:42:02 am
carrizog60
  • 978
1.9 TD real power
« Reply #6 on: December 26, 2007, 04:42:02 am »
to clear out the smoke...
i prefer on having a better combustion than a smokey one ...
it also helps keep egt down.
even i only get 30 psi at redline(bloked WG)
Portugal
Reply #7December 26, 2007, 05:45:47 am
flash319
  • 163
1.9 TD real power
« Reply #7 on: December 26, 2007, 05:45:47 am »
Ya I think 180f/lb is a bit high.  I would be more then happy with 140.  Thanks for the info so far...............
Reply #8December 26, 2007, 06:44:36 am
1.9 TD real power
« Reply #8 on: December 26, 2007, 06:44:36 am »
I think 140 ft/lbs would be easily obtainable. My AAZ is in a 4wd with losses of both an extra overdrive, transfer case and 32" tires. With the fuel not turned up much if any(previous owner said it was turned up a little) I dynoed at 80 hp and 122.5 ft/lbs.
Reply #9December 26, 2007, 06:55:10 am
flash319
  • 163
1.9 TD real power
« Reply #9 on: December 26, 2007, 06:55:10 am »
Jimfoo, My plan is for putting a AAZ out of my 97 Jetta (1.9L K03 Turbo) into a 4X4 Toyota truck.  What is yours in?  I have been planing this for a while but I get some people saying it will be horribly under powered and others saying it will be fine (these guys have 1.6L in Samys).  I have a 22RE in the truck now and it is rated at 110hp and 140ft/lb (Peak HP is at 3800rpm, Peak torque is 3200rpm).  If I can match that then I would be more then happy.  I just don't want to dive into this without knowing what the end result is going to be.
PS sorry just read what you have it in................
Reply #10December 26, 2007, 07:08:27 am
1.9 TD real power
« Reply #10 on: December 26, 2007, 07:08:27 am »
The only problem I had was for some reason I never figured out my engine got really hot going up long hills/passes. It could have been my radiator was just a bit too small, thermostat or water pump problem, I never really found out. So I would have to go much slower up hills than I otherwise could have to try to keep the engine cool. My truck weighs 3500 lbs and my old gas engine had 42 hp@3500 and 83 ft/lbs@1500, so to me the power was great. I got close to 30 pg on the highway, but I'm shaped like a brick. I would thing a Toy would do a bit better, especially if the gearing is better, which I think it is. My truck has 4.7's so I'm doing about 3k rpm at 65. My AAZ's torque and HP peak was around 3500 rpm. If I didn't have the heat problem, I'm sure I could have turned the fuel up more and done even better., plus my radiator size was limited to about 18-20" width. You could probably fit a bigger one if you needed.
Reply #11December 28, 2007, 05:56:06 am
nogama3
  • 162
1.9 TD real power
« Reply #11 on: December 28, 2007, 05:56:06 am »
i have a 1.9 aaz TD engine and have upped the boost and added an intercooler from a Golf mk3 TDI and am now running at 100bhp (1.0bar boost). looking at adding a larger sharan intercooler on the front in the future - its sitting in the garage at the moment.
