Author Topic: Turbo'ing my NA 1.6d  (Read 5099 times)
December 19, 2007, 01:54:17 am
vw-uziel
  • 5
« on: December 19, 2007, 01:54:17 am »
Hi all,
Ok, I got all the parts (I hope) to turbo my 1.6d. Now, the block is a NA1.6 with NA 1.6 pistons. I don't want to go over normal boost 10PSI?. Will the pistons be ok?
I am new to this all so please excuse me for dumb questions.
Reply #1December 19, 2007, 02:43:52 am
carrizog60
  • 978
« Reply #1 on: December 19, 2007, 02:43:52 am »
JK with all external stuff from a gtd+external oil cooler and front mount intercooler.
just installed metal gasket and merc. injectors and its holding fine for now. :wink:
Portugal
Reply #2December 19, 2007, 03:36:29 pm
raziso
  • 1
« Reply #2 on: December 19, 2007, 03:36:29 pm »
I've looked into this myself.  Where do you connect oil feed from the motor?  I assume you drill a hole into the oil pan for the return.
Reply #3December 19, 2007, 05:22:20 pm
dillenger1
  • 777
« Reply #3 on: December 19, 2007, 05:22:20 pm »
I would like to know the(sweet spot) to drill/tap for an line.If anyones got pics that would be great
1.6td in toyota pickup
10mm head ,t3 intercooled.
Reply #4December 19, 2007, 05:45:58 pm
  • 5104
« Reply #4 on: December 19, 2007, 05:45:58 pm »
most people us the sandwich deal from a volvo, it goes between the filter and the filter flange.
Reply #5December 19, 2007, 06:08:27 pm
blkboostedtruck
  • 1535
« Reply #5 on: December 19, 2007, 06:08:27 pm »
Quote from: "dillenger1"
 the real sweet spot is in the block! drill and tap the block for the oil return line from the Turbo! but there are all sorts of different routs you can go!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #6December 20, 2007, 08:57:30 pm
mac.man25
  • 50
« Reply #6 on: December 20, 2007, 08:57:30 pm »
Not to highjack, but:
Is the exhaust manifold the same height as the NA manifold so you can just bolt (Spring?) up the same exhaust?  I am considering doing a complete TD swap in my NA Golf and was wondering I would have to redo the exhaust.
'83 VW Pickup, Getting the AAZ.
86 BMW 325es.
Reply #7December 20, 2007, 09:02:55 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #7 on: December 20, 2007, 09:02:55 pm »
not same height.
Reply #8December 20, 2007, 10:46:46 pm
« Reply #8 on: December 20, 2007, 10:46:46 pm »
I think it's close enough that it doesn't matter. I swapped a 1.6 NA into a mk2 that had a 1.6 TD and a 1.9 TD in it over the course of it's life. The downpipe didn't have to be changed
Reply #9December 20, 2007, 10:50:07 pm
mac.man25
  • 50
« Reply #9 on: December 20, 2007, 10:50:07 pm »
Quote from: "burn_your_money"
Thanks.  [END OF HIJACK]
86 BMW 325es.
Reply #10December 20, 2007, 10:52:27 pm
vanagonturbo
  • 639
    • Fine Tuning
« Reply #10 on: December 20, 2007, 10:52:27 pm »
I was thinking MKI. Its off by about 2-3 inches IIRC. I know I had to section the downpipe on my last Scirocco TD just to make sure the rest of the exhaust was straight. not sure on the MKII but I know its a different length there too. You could run into steering rack rubbage...
To the OP, I think you would be just fine with what you have. The amount of boost is pretty much irrelevant as more boost lowers EGTs on the Diesel which is the opposite of a gasser. Make sure you put a preturbo EGT probe in with a pyrometer to monitor the temps. That way you can KNOW if you are doing damage to the engine and tune accordingly.
[runs an 11mm NA engine @23 PSI]
Reply #11December 20, 2007, 11:11:03 pm
bignivanut
  • 11
« Reply #11 on: December 20, 2007, 11:11:03 pm »
Did you say diesel Scirocco?     HMMMM.    what about a TDI-M  in a Scirocco?  :idea:
Sorry for the compression ignition interjection.  I haven't been here for a while and the Scirocco diesel thing caught my interest in a big way.  :o
Thanks for the  :idea:  :D
Compression Ignition Rules!
Reply #12December 26, 2007, 11:17:59 pm
vw-uziel
  • 5
« Reply #12 on: December 26, 2007, 11:17:59 pm »
Hi All...
This past  weekend I put on the turbo for my NA Diesel. One question, it smokes like crazy...black smoke...is this normal?
Reply #13December 26, 2007, 11:21:55 pm
« Reply #13 on: December 26, 2007, 11:21:55 pm »
Quote from: "carrizog60"
201.9 ft/lbs torque? wow nice!
Reply #14December 27, 2007, 03:20:14 am
carrizog60
  • 978
« Reply #14 on: December 27, 2007, 03:20:14 am »
i guesse when doing the governor mod it should kick more torque.
luckly it only comes at high rpm,my clutch says thanks :lol:
Portugal
