Author Topic: 1.6L Block with a 1.5L head - It's alive  (Read 2028 times)
December 18, 2007, 07:06:15 pm
ilomax
  • 86
« on: December 18, 2007, 07:06:15 pm »
The wanted to say that my mix and match engine runs great.
Recap:
- 1.5L head
- 11mm 1.6L block
- 1.5L 5 notch head gasket
Every thing went smooth, got all the little nuts and bolts replaced were nasty, found out the clutch was almost new, cleaned everything up, and I everything is the way that I want it to be.
The only minor issue was that the oil return on the block was actually a little bigger than the head gasket itself.  A little high temp RTV around the oil return and problem solved.
The car runs like a champ...We'll see how long that lasts.
2001 Audi A8L - Air Ride Suspension - Car PC - 19" Work Equipped Euroline DH - For Sale / $18,000.
1984 Rabbit - Daily driver smoke machine - Can't complain about 23 year old technology that gets 45 MPG.
Reply #1December 18, 2007, 07:20:41 pm
Powered by Spearco
  • 1203
« Reply #1 on: December 18, 2007, 07:20:41 pm »
Happy to here that the motor I sold you worked out ok.
You should be good for a while, at least this winter.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
