Author Topic: Taking apart injectors  (Read 4241 times)
December 16, 2007, 05:40:24 pm
hamradio
  • 282
« on: December 16, 2007, 05:40:24 pm »
Hi,
can I safely disassemble and reassemble an injector, for cleaning purposes, without doing damage or messing anything up?
Reply #1December 16, 2007, 08:11:02 pm
CoolAirVw
  • 175
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #2December 17, 2007, 01:53:24 pm
hamradio
  • 282
« Reply #2 on: December 17, 2007, 01:53:24 pm »
Thank you very much!  Very helpful!
Where do I get new nozzles, and how much are they?
Reply #3December 17, 2007, 05:58:39 pm
oldskool rich
  • 446
« Reply #3 on: December 17, 2007, 05:58:39 pm »
i got my merc nozzels for £60 from bosch
f6squared I.D.S.T
Reply #4December 17, 2007, 06:37:23 pm
« Reply #4 on: December 17, 2007, 06:37:23 pm »
Quote from: "hamradio"
The vast array of Worldpac suppliers has them at around the $15 dollar mark each.
BTW... it would be helpful if your QTH was in your profile... the answers to questions like this can be different depending on where on the globe you live !
previously known as VE1BAI.... many moons ago.
Reply #5December 17, 2007, 09:51:43 pm
duffer
  • 164
« Reply #5 on: December 17, 2007, 09:51:43 pm »
Quote from: "Vincent Waldon"
Which nozzles are you referring to at $15?
www.autohausaz sells the 0434 250 103 nozzles for about $8-9.
but the 0434 250 138 (DNO SD273) nozzles are $26.64.
I bought the latter, but I'd rather pay $15 than $26.64 :)
Reply #6December 17, 2007, 10:26:41 pm
« Reply #6 on: December 17, 2007, 10:26:41 pm »
Of course they're out of stock at the moment... so they don't appear in the price listings, but I just bought four 173s for 15 bucks each from bestpriceautoparts.ca.
Reply #7December 18, 2007, 01:16:31 am
OM617
« Reply #7 on: December 18, 2007, 01:16:31 am »
Injectors are very precise devices.
Wear clean gloves lubricated in diesel. The acids in your finger's oils can permanently etch the unprotected surface of the nozzles.
Always keep the injector nozzles separate from each other. The nozzles are closely matched to their nozzle body. The injector bodies have a specific thickness spring shim to set he pop pressure.
And as always, use a torque wrench to put them together, don't just muscle them tight.
Reply #8December 18, 2007, 02:26:53 am
Op-Ivy
  • 513
« Reply #8 on: December 18, 2007, 02:26:53 am »
Sorry to thread jack but... Do you have to pop test them after following the rebuild procedure?
Reply #9December 18, 2007, 03:28:09 am
« Reply #9 on: December 18, 2007, 03:28:09 am »
Quote from: "Op-Ivy"
no.  but it is a really good idea!  spray pattern is much more crucial than pop pressure, unless the pop pressure is way off and starts to affect timing.
Reply #10December 18, 2007, 09:21:11 am
« Reply #10 on: December 18, 2007, 09:21:11 am »
My vote would be "yes"; it's a great idea to test/calibrate them after rebuilding... for a couple of reasons:
- I personally find the rebuilding process tends to up the breaking pressure... sometimes substantially.  Perhaps I lap too much... ;-)
- quite possible to get a bum nozzle from the factory, or have something in the injector bind etc.  Both have happened to me.
- it's nice to confirm they are not going to leak *before* installation
Reply #11December 19, 2007, 03:18:22 am
vw-uziel
  • 5
« Reply #11 on: December 19, 2007, 03:18:22 am »
Ok, what injectors do i need for the turbo setup on my car. I live in South Africa so VW diesel stuff is quite scares here.
Reply #12December 19, 2007, 03:44:11 pm
blkboostedtruck
  • 1535
« Reply #12 on: December 19, 2007, 03:44:11 pm »
if you have a TD pump that has the LDA on top use the 155 bar injectors!
Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
