General Information
Troubleshooting
filling the trans with gear lube. 1994 aaz
Topic: filling the trans with gear lube. 1994 aaz (Read 3839 times)
December 15, 2007, 09:00:00 am
trent77
December 15, 2007, 09:00:00 am »
I noticed in my bentley that they say to fill trans at speedo gear location. But it also says they moved the check plug before my trans was built. on an aaz trans do I still fill it at the speedo location? thanks
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
December 15, 2007, 08:52:22 pm
trent77
December 15, 2007, 08:52:22 pm »
anybody?
77 westfalia
06 GMC Duramax
December 15, 2007, 08:59:11 pm
December 15, 2007, 08:59:11 pm »
You likely have an 020 transmission (cable clutch, right ?)... if so.. here's the definitive work on the subject with some great pictures:
www.brokevw.com
December 16, 2007, 03:09:10 am
Ziptar
December 16, 2007, 03:09:10 am »
You can use the speedo hole or the check hole. It all winds up in the same place.
I use the speedo hole. A small funnel, 2 quarts of lube, in and done.
General Information
Troubleshooting
