Author Topic: Finally did it...  (Read 2091 times)
December 10, 2007, 10:42:24 pm
MaxHedrm
  • 114
    • blog
Finally did it...
« on: December 10, 2007, 10:42:24 pm »
I had to, the city finally noticed the car sitting in my driveway, unregistered & uninspected. I couldn't let them take it, so I have to fix it.
Well, I'm mostly done.  Finally got off my lazy butt & pulled the head. Cleaned it all up as good as possible, the coolant passages were nasty. All full of diesel/coolant/oil sludge from when the old headgasket croaked. & now it's mostly back together. I have to hook up the new coolant hoses & probably should drain the fuel tank some at least, since it's been sitting over a year now. Then fill up the fluids & give it a try.
Any suggestions on what to flush the cooling system with? I know I didn't get it all out, & I'm sure the heater core & everything else is disgusting too.
One of the pistons was ever so slightly pitted. I meant to get pics, but never went in to get my camera. Is it something I should worry about? To my novice eyes everything else looked pretty good for a car that claims to have 362,000 miles.
And I only broke one bolt (to the front coolant flange, ooops) & one little vacuum splitter (gonna have to work around this for now). I also managed to lose one washer for one of the nuts on the exhaust manifold.  :?
DRIVE: 2010 Golf TDI
DRIVE (less): 2001 TT Roadster
Reply #1December 11, 2007, 05:05:05 am
Finally did it...
« Reply #1 on: December 11, 2007, 05:05:05 am »
Way to save one of the good ones :D
Reply #2December 11, 2007, 02:07:20 pm
veeman
  • 421
Finally did it...
« Reply #2 on: December 11, 2007, 02:07:20 pm »
A friend of mine had a few Passats / Audi's come through with bad oil coolers on the 1.8T engine.  Oil got into the coolant system and made a terrible mess.  After replacing the parts they needed, he used Dawn dishwashing detergent (not a whole lot) and a bunch of water to flush it all out.   Seemed to work pretty well...
81 Caddy TD
98 Audi A4 Quattro V6 TDI
83 VW GTI FSP
86 4ktq
