Author Topic: loosing coolant  (Read 3995 times)
December 10, 2007, 05:42:55 pm
passtgt
  • 10
loosing coolant
« on: December 10, 2007, 05:42:55 pm »
hey guys .. im having a problem with my 1.9 td passat.  every couple  of weeks i have to add coolant.  i do not see any leaks and i do not have coolant in my oil. any idea where my coolant is going?? thanx much
91 passat 16v
93 passat 1.9td
http://www.theb3e.com
Reply #1December 10, 2007, 07:20:32 pm
loosing coolant
« Reply #1 on: December 10, 2007, 07:20:32 pm »
could be anything... leaky heat exchanger, rad, hose, head gasket, faulty expansion tank/cap.
you'll probably need to get the system tested somewhere.. maybe even with a UV detection dye.  i guess you could also just use food colouring to make it more obvious.  keep an eye near the head gasket for leaks.  if that is leaking it will most likely give you some problems later.
Reply #2December 10, 2007, 08:37:23 pm
loosing coolant
« Reply #2 on: December 10, 2007, 08:37:23 pm »
Wash the engine so it's nice and clean.
You might just have a defective rad cap and the coolant is boiling over
Use one of those gauges and test the concentration of the coolant. If there is more antifreeze then water the water is probably boiling off
Reply #3December 13, 2007, 06:23:10 pm
passtgt
  • 10
loosing coolant
« Reply #3 on: December 13, 2007, 06:23:10 pm »
thanks guys i think ive narowed it down to a leak around the coolant pump.  i will have a closer look on the weekend
91 passat 16v
93 passat 1.9td
