Author Topic: extended metal arches  (Read 5973 times)
November 30, 2007, 04:25:38 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« on: November 30, 2007, 04:25:38 am »
I need to fit arch repair sections to my rear arches where as there a bit rusty in places, to extend them do I buy an extra set of repair sections cut the lip off the and cut up a second set of front wings and repair plates weld em on grind the welds down and use filler to blend them in? :| I'll also be filling the holes for the side trims then respraying the whole car satin black
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #1November 30, 2007, 07:35:06 am
« Reply #1 on: November 30, 2007, 07:35:06 am »
From what I've seen from other peoples projects is they notch the stock flairs, pull them out and weld in filler metal. Then grind and smooth.
Reply #2January 08, 2008, 05:56:58 pm
silvertdi
  • 125
« Reply #2 on: January 08, 2008, 05:56:58 pm »
Reply #3January 08, 2008, 06:38:53 pm
« Reply #3 on: January 08, 2008, 06:38:53 pm »
Do you have the images uploaded to the internet ( www.photobucket.com www.imageshack.com ) etc?
Reply #4January 08, 2008, 08:37:47 pm
silvertdi
  • 125
« Reply #4 on: January 08, 2008, 08:37:47 pm »
I just uploaded the photos to photobucket.  What do I do now?
Reply #5January 08, 2008, 09:07:28 pm
Op-Ivy
  • 513
« Reply #5 on: January 08, 2008, 09:07:28 pm »
Quote from: "burn_your_money"
Yeap. That's how I've seen it done as well. Looks good when done but I can imagine it would be hard to make them all even. I wouldn't mind seeing a picture of some. Haven't been able to find any :(
Reply #6January 09, 2008, 05:34:22 pm
silvertdi
  • 125
« Reply #6 on: January 09, 2008, 05:34:22 pm »
I'll post some pictures if someone could tell me how.  I just placed them in photobucket.  I apologize for my ignorance.   :)
Reply #7January 09, 2008, 05:50:35 pm
b1rdjx88
« Reply #7 on: January 09, 2008, 05:50:35 pm »
Go to your pictures in photobucket and copy the url from the address bar on your browser:
eg:  url= "http://www.photobucket.com/myphotos/photo1.jpg"
Then to post them here, type the following code into the message body of your post:
Code: [Select]
 [img] http://www.photobucket.com/myphotos/photo1.jpg [/img]
There are also buttons below the subject field which will type the codes in automatically for you.
Reply #8January 09, 2008, 06:00:18 pm
silvertdi
  • 125
« Reply #8 on: January 09, 2008, 06:00:18 pm »
Thanks.  Let's see if this works.  It's not my car.  Just some pictures I found and was holding onto for ideas.
[/img]http://i245.photobucket.com/albums/gg46/silvertdi/p9647864561.jpghttp://i245.photobucket.com/albums/gg46/silvertdi/ww200341.jpg
Reply #9January 09, 2008, 06:11:52 pm
silvertdi
  • 125
« Reply #9 on: January 09, 2008, 06:11:52 pm »
Reply #10January 09, 2008, 07:48:28 pm
Op-Ivy
  • 513
« Reply #10 on: January 09, 2008, 07:48:28 pm »
Looks good up close! I still think it would be hard to keep even on all corners :P
Maybe if I have some time. :)
Reply #11January 10, 2008, 06:36:48 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #11 on: January 10, 2008, 06:36:48 am »
Calvin
91 VW Golf 1.6NA 5spd
Reply #12January 10, 2008, 05:20:30 pm
silvertdi
  • 125
« Reply #12 on: January 10, 2008, 05:20:30 pm »
It looks like he took air snips and carefully cut the lip from the body leaving the two bases of the wheel well arch uncut.  Then bent it out a few inches, tacked in some spacers, cut and rolled some metal, welded it in, and did the remaining bodywork.  It doesn't look too tough, but then again, I'm not a bodyshop guru.  :D
Reply #13January 10, 2008, 10:53:28 pm
« Reply #13 on: January 10, 2008, 10:53:28 pm »
Quote from: "Op-Ivy"
As long as it's close I don't think anyone would notice. Of course it all depends on what you are going for
