Author Topic: Electrical short problem and question  (Read 4001 times)
November 29, 2007, 04:35:26 pm
mtnbob
  • 738
« on: November 29, 2007, 04:35:26 pm »
Car wouldn't start tonight. Battery was fine, clicking under the hood, just once every time i turned the key, not repeatedly like when the starter is going out. While i turned the steering wheel, the horn beeped a little own its own then stopped. I couldn't jumpstart it, nothing happened. I managed to push start it my self(thank god it starts easy), and drove it 35 miles home with no problem. When i shut it off in the driveway, it restarted easily like nothing was ever wrong. I know these things don't fix themselves for long :wink: Any suggestions where to start? Could there a connection between the steering making the horn sound a little, and the car not starting? Would the relay make any difference? I had my cold start relay replaced with a used one(all I could find at the time). I bought one to have a spare anyway. Or doesn't that only affect the glow plugs?
96 Subaru Outback Wagon
Reply #1November 29, 2007, 10:50:09 pm
« Reply #1 on: November 29, 2007, 10:50:09 pm »
What is a cold start relay? the x-relay?
It sounds like you have a bad ground from the engine to the battery. You can check it for voltage drop. Anything over 0.2v while the cable is carrying a load (ie cranking) and the cable needs to be replaced or the connection cleaned/tightened.
Reply #2November 29, 2007, 11:15:35 pm
mtnbob
  • 738
« Reply #2 on: November 29, 2007, 11:15:35 pm »
ok ty
it kinda worries me though when the horn is slightly triggered from turning the steering wheel. wondering if i have a short in there. :shock:
Reply #3November 29, 2007, 11:31:35 pm
« Reply #3 on: November 29, 2007, 11:31:35 pm »
The steering rack has it's own ground to body... I think. Unless that's only mk1s... or chevettes. It's too late for this kind of thinking
