There is a brass insert in the pin holes, I'll assume that's standard since I don't have any others in front of me.Top of pin hole to top of piston: 32.70mm.Bottom of pin hole to bottom of piston directly below hole: 7.98mmHowever, the skirts are longer front & back than on the sides where the pin is, so it appears to be ~13.15mm from the bottom of the pin hole to the lowest part of the skirt.Taken as approximates, that should tell you whether it's within the margin of error or unworkable.Let me know if you'd like anything else
