Author Topic: Starter bits  (Read 4189 times)
November 27, 2007, 05:27:40 am
addautomotive
Starter bits
« on: November 27, 2007, 05:27:40 am »
I have a box 'o starters that have bad feed wires, bad solenoids or bad brushes.
I'd like to take my 4 junk starters and make a couple good ones. Where can a fellah get a brush kit, or a solenoid?
Reply #1November 27, 2007, 07:02:14 pm
bvolks73
  • 183
Starter bits
« Reply #1 on: November 27, 2007, 07:02:14 pm »
Here in Fredericton I get mine from CMAC or Piercy's so I imagine and starter/ alternator repair place should have them. Piercy's spot welded my brushes on and assembled my starter for $30 a few years ago (including the price of a new tracking gear I bought from him).
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #2November 28, 2007, 03:18:36 am
Doug
Starter bits
« Reply #2 on: November 28, 2007, 03:18:36 am »
Your local auto electric repair place will be able to get you the brushes as well as the cabling needed to run into the starter. I have found that the cabling will fail open due to corrosion of the fine copper wire braid under the sheath. It is a cheap fix for a starter motor that has just quit.
