Author Topic: cooling issue  (Read 3916 times)
November 21, 2007, 02:43:39 pm
fillmore
  • 60
    • http://fillmorenorthband.tripod.com
cooling issue
« on: November 21, 2007, 02:43:39 pm »
having another problem with my AAZ 1.9td, i started the car up today and my temp light was flashing, i checked the coolent level as well as the sensors, everything appeared to be fine. i let the engine idle for a couple minutes and noticed that all the coolent hoses were getting warm except for the head to rad and the waterpump to rad, after a quick spin in the car i came back and now the upper rad hose had warm coolent in it but the lower hose was still ice cold (but not filled with ice :wink: ) could this be a bad thermostat? it is located in the waterpump right?
thanks in advance
Reply #1November 21, 2007, 07:32:42 pm
g-spec
  • 289
cooling issue
« Reply #1 on: November 21, 2007, 07:32:42 pm »
Does the car start to overheat???? sounds like a thermostat or waterpump!!!!
Reply #2November 21, 2007, 08:33:09 pm
fillmore
  • 60
cooling issue
« Reply #2 on: November 21, 2007, 08:33:09 pm »
no car does not overheat, the temp gauge does not move
