Author Topic: Giles, Dr. Diesel, HELP ME!!!!!!  (Read 4594 times)
March 13, 2005, 06:26:27 pm
TDIMeister
  • 284
« on: March 13, 2005, 06:26:27 pm »
First off, sorry to Marc and others if this is the wrong place for this...
I donno if Giles would be able to help me, but I have a new TDI pump with an upgraded 12mm head installed.  I tried to install it into my car a few weekends ago, but it won't run.  The engine would crank for a long time, catch for a split second, and then die again.  I have a hunch (and hope this is all) that either the injection quantity adjustment or timing is out of whack.
I don't know what tests can be done on a bench, but I would be willing to come up to wherever you are (Markham?) to drop off the pump for you to take a look at it (I'm in Oakville).
Could you please reply here or PM?  Thanks.
Dave
Reply #1March 14, 2005, 04:41:27 am
RedRotors
  • 734
    • http://www.mikrotuning.com
« Reply #1 on: March 14, 2005, 04:41:27 am »
No problem Dave.. If the head is in trouble, i have an other one that i can send to you.. Btw,did you get the cam ?
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #2March 14, 2005, 06:26:02 am
caddy
  • 748
« Reply #2 on: March 14, 2005, 06:26:02 am »
may be check the timing between the head and the drive shaft.
or make a 180° timing adjust on your pump to see if trouble is coming about this.
Reply #3March 14, 2005, 09:47:19 am
TDIMeister
  • 284
« Reply #3 on: March 14, 2005, 09:47:19 am »
Quote from: "RedRotors"
Marc/
Marc, yes, I got the notification from Canada Post to pick it up.  I will do so on my way home today! :)
