Author Topic: DiesOtto Now I have seen it all...  (Read 6754 times)
November 15, 2007, 08:22:18 pm
Ziptar
  • 565
« on: November 15, 2007, 08:22:18 pm »
http://www.gizmag.com/go/7679/
Gasoline Engine uses Direct Injection and Compression ignition sometimes....
When starting and under full load, the fuel/air mixture is ignited by a spark plug, as in a conventional spark-ignition engine (homogeneous combustion). The controlled auto ignition to which the DiesOtto automatically reverts within its working cycle occurs under partial load conditions, i.e. at low and medium engine speeds.
So it starts out Spark + Gas and them morphs into a "Diesel" using gasoline.
 :shock:  Must really be something to work on..
Reply #1November 16, 2007, 04:58:33 am
Turbinepowered
  • 1206
« Reply #1 on: November 16, 2007, 04:58:33 am »
Betcha longevity will be worse than either straight gas or straight diesel engines, too. So much complexity and precision little microbits to fail...
Nice idea, though. Supposedly this is being heralded as diesel's "coming doom."
Reply #2November 16, 2007, 06:31:58 am
« Reply #2 on: November 16, 2007, 06:31:58 am »
don't worry.. it's just a concept car.  mercedes wouldn't release a problematic vehicle to ruin its reputation.  not like the vw touareg...  :lol:
the idea behind it is really interesting though, but i think a diesel/propane combination would be more beneficial  :twisted:
Reply #3November 16, 2007, 07:04:04 am
Turbinepowered
  • 1206
« Reply #3 on: November 16, 2007, 07:04:04 am »
Quote from: "jtanguay"
Methane and it could be 100% renewably fueled. :D
Reply #4November 16, 2007, 07:30:11 am
« Reply #4 on: November 16, 2007, 07:30:11 am »
lol methane... such a volatile gas!  would need to be injected at the same time as the diesel, but it would burn more rapidly.
would be cool for cow/dairy farmers!  methane injection  :twisted:
Reply #5November 16, 2007, 10:27:03 am
rov716y
  • 96
« Reply #5 on: November 16, 2007, 10:27:03 am »
The result is an 1800cc four-cylinder motor producing 238 bhp (175 kW) with torque of 400 nm while delivering 6 l/100 km (47 UK mpg, 40 US mpg) in an S-class.
:shock:  :shock:  :shock:
Reply #6November 16, 2007, 11:37:37 am
Slave2School
  • 531
« Reply #6 on: November 16, 2007, 11:37:37 am »
Quote from: "rov716y"
If driven with a light foot lol, I bet for any form of performance driving (not read the article) that is reverts to spark only mode and chugs back the fuel the same as any other car would.
2002 ford focme wagon
Reply #7November 16, 2007, 03:48:01 pm
« Reply #7 on: November 16, 2007, 03:48:01 pm »
Quote from: "Slave2School"
depending on driving style really... low end it gives you mad diesel torque, and higher rpm band it gives you gasser torque (good for autocrossing i suppose)
just stay out of 4k+ rpm's and you'll get the good mileage :)
Reply #8November 16, 2007, 04:13:24 pm
Slave2School
  • 531
« Reply #8 on: November 16, 2007, 04:13:24 pm »
Direct injection alone would really help, I would like to try out the new TSI engines that VW has :)  It is good to see advancements like this that are allowing gasoline engines do what diesels have for the last 25 years :D
Reply #9November 16, 2007, 09:17:35 pm
dieselsnowmobile
  • 103
« Reply #9 on: November 16, 2007, 09:17:35 pm »
They ought to make a V8 or V4 with half of the engine a diesel and the other half a gas.  This would combine torque and power.  The only problem would be two gas tanks for each fuel.
'89 1.6L NA Diesel Jetta (469,100 mi) w/ Rabbit Engine (242,500 mi)
