Author Topic: W.T.B. small assortment of injector shims 10 of each size  (Read 9712 times)
November 15, 2007, 02:34:07 pm
blkboostedtruck
  • 1535
« on: November 15, 2007, 02:34:07 pm »
like the add says i'm looking for small assortment of injector shims like 10 of each size! all the local injection shops want to sell me 50 of each size and that way to much and at the cost of 500 bucks for them! if anybody gots a small quanity or would like to split a large set of shims let me know?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #1November 16, 2007, 08:44:29 am
« Reply #1 on: November 16, 2007, 08:44:29 am »
I'd pay 50 bucks for 5 of each size... can we find more people like me ??
Reply #2November 16, 2007, 10:50:45 am
« Reply #2 on: November 16, 2007, 10:50:45 am »
what kind of material are the shims made of? regular steel? heat treated steel? coated???
maybe some machine shop could make you some for relatively cheap...
Reply #3November 20, 2007, 05:41:28 pm
blkboostedtruck
  • 1535
« Reply #3 on: November 20, 2007, 05:41:28 pm »
I've been told that there is a shim punch tool to make shims for injectors!
 does anyone know who makes this tool and where i and sure others would like to find it also? anybody know? because i can find the shim stock!
how about are friends over the pond?
thanks Duane
'66 variant 1500S
Reply #4November 20, 2007, 06:16:14 pm
Turbinepowered
  • 1206
« Reply #4 on: November 20, 2007, 06:16:14 pm »
Quote from: "jtanguay"
I seem to remember reading something about them being hardened.
I'd be in for a set of shims. How many shim sizes are there?
Reply #5November 21, 2007, 07:47:25 am
myke_w
  • 1099
« Reply #5 on: November 21, 2007, 07:47:25 am »
There are 30 sizes - they range from 2.85 mm to 4.30 mm in .05 increments
most cost about 1.50 each (from me anyway), some are in short supply.
IIRC they are hardened, they do get pretty high shear forces acting on them.
I have very rarely seen them near the extreme sizes (under 3mm or over 4mm). The only way I could imagine you would need extreme sizes would be because a head re builder either failed to grind the stem to the proper length for seat depth during a valve job (you'd end up with very thin shims) or they took alot off the stem (you'd end up with thick ones).
A whole kit including 5 each of 24 sizes 3.05-4.20mm, totaling 120 Shims in a divided box costs about 175 bucks through my supplier.
It's CRP brand (Continental)
Reply #6November 21, 2007, 08:12:11 am
Turbinepowered
  • 1206
« Reply #6 on: November 21, 2007, 08:12:11 am »
Those look like valve shims, he's talking injector shims...
Reply #7November 21, 2007, 08:18:01 am
myke_w
  • 1099
« Reply #7 on: November 21, 2007, 08:18:01 am »
DOH! :oops:
well bump for ya anyway buddy :)
Reply #8November 21, 2007, 08:55:22 am
BlackTieTD
  • 1512
« Reply #8 on: November 21, 2007, 08:55:22 am »
well then how many thicknesses of injector shim are there? i've only ever used one and the dealer only spec's one. i could have been using many thicknesses and never known it if i've never specified....
Reply #9November 21, 2007, 11:21:37 am
blkboostedtruck
  • 1535
« Reply #9 on: November 21, 2007, 11:21:37 am »
as far as i can tell! but i don't know for sure? there is 20 different sizes.
Tintin sent me a link to a supplyer but i can't read it? try WWW.DIESELSEND.DE maybe one of you guys can translate the site?
let us know what it says? and i'm still trying to find a tool to make these shims because i think thats the best way to go? so if anyone knows where to look? or knows someone that can make a custom tool to do this! let me know?
thanks  Duane
'66 variant 1500S
Reply #10November 21, 2007, 12:19:06 pm
« Reply #10 on: November 21, 2007, 12:19:06 pm »
Quote from: "BlackTieTD"
I think you may be referring to the heat shield no?
Reply #11November 21, 2007, 12:51:49 pm
saurkraut
  • 904
« Reply #11 on: November 21, 2007, 12:51:49 pm »
From Tools on WWW.DIESELSEND.DE (paste into altavista bablefish)
Setting shims for KCA, KBA, KDA nozzle holder
Diameter 11.5 mm
Assortment:
Diameter 11.5 mm of drilling 3.2 mm
Thickness [ mm ]
0,05 - 0.10 - 0.84 - 0.90 - 0,94
1,00 - 1.04 - 1.10 - 1.14 - 1,20
1,24 - 1.34 - 1.40 - 1.50 - 1,54
1,64 - 1.70 - 1.74 - 1.80 - 1,84 SET 100 pieces of 11,5mm 5 pieces for each thickness EUR 38, - -
SET 200 pieces of 11,5mm 10 pieces for each thickness EUR 67, - -
SET 400 pieces of 11,5mm 20 pieces for each thickness EUR 120, - -
packed in Polybeuteln with Klippverschluss
Setting shims for KCE, KBE, KDE nozzle holder
Diameter 9.8 mm
Assortment:
Diameter 9.8 mm of drilling 3.2 mm
Thickness [ mm ]
1,00 - 1.06 - 1.12 - 1.18 - 1,24
1,30 - 1.36 - 1.40 - 1.42 - 1,48
1,54 - 1.60 - 1.66 - 1.72 - 1,78
1,84 - 1.90 - 1,96 SET 90 pieces of 9,8mm 5 pieces for each thickness EUR 36, - -
SET 180 pieces of 9,8mm 10 pieces for each thickness EUR 64, - -
Setting shims for div. KBEL, KDEL nozzle holder, stage owner Actros etc., 2-Feder KCA27S77 (opening pressure)
Diameter 8.5 mm
Assortment:
Diameter 8.5 mm of drilling approx.. 2.8 mm
Thickness [ mm ]
0,80 - 0.85 - 0.90 - 1.00 - 1,05
1,10 - 1.15 - 1.20 - 1.25 - 1,30
1,35 - 1.40 - 1.45 - 1.50 - 1,55
1,60 - 1.65 - 1.70 - 1.75 - 1,80
1,85 - 1.90 - 1.95 - 2,00 SET 125 pieces of 8.5 mm of 24 strengths, ever 5 pieces of EUR 53, - -
Setting shims for 2-Feder KB L L (TDi, opening pressure)
and Japanese nozzle holders
Diameter 6.8 mm
Assortment:
Diameter 6.8 mm of drilling 3.2 mm
Thickness [ mm ]
1,05 - 1.10 - 1.15 - 1.20 - 1,25
1,30 - 1.35 - 1.40 - 1.50 - 1,55
1,60 - 1.70 - 1.75 - 1.80 - 1,85
1,90 - 1.95 - 2,00 SET 90 pieces of 6,8mm 5 pieces for each thickness EUR 36, - -
SET 180 pieces of 6,8mm 10 pieces for each thickness EUR 64, - -
Prices inclusive. 19% VAT, valid for October 2007. Change and mistake reserve.
The general trading conditions apply.
 Inquiry/order
  read updates: 14.07.2007 12:30
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #12November 21, 2007, 02:46:54 pm
blkboostedtruck
  • 1535
« Reply #12 on: November 21, 2007, 02:46:54 pm »
saurkraut,
you did a good job can you translate the prices to us dollars?
thanks Duane
'66 variant 1500S
Reply #13November 22, 2007, 12:48:44 pm
« Reply #13 on: November 22, 2007, 12:48:44 pm »
www.xe.com for currency conversions
Reply #14November 22, 2007, 05:23:09 pm
blkboostedtruck
  • 1535
« Reply #14 on: November 22, 2007, 05:23:09 pm »
thanks Tyler!
that helps I saved it to! now i don't need to ask all the time!
thanks Duane
'66 variant 1500S
