Author Topic: Temp gauge reads high with cold engine and hard cold start  (Read 4991 times)
November 12, 2007, 02:29:03 pm
Dieseleo
  • 2
« on: November 12, 2007, 02:29:03 pm »
My temp gauge maxes out and blinks even when the engine is still cold, and the car won't start when it gets below forty degrees outside. I don't know if these things are related or not. It's an 86 Golf. The gauge seemed to work fine when it was warm outside, and after the car runs for a while it corrects itself and reads at the normal operating temp. The glow plugs are good, I think the fuel lines and injectors are fine. There's a little white smoke when trying to start but not a cloud or anything that bad. I don't get much heat out of the blowers either. My Bentley says something about a sending unit that could be screwed up, but then doesn't say anything about what it is or how to replace it. Winter's coming, and I just got a job, so I need this little #&*@! to start dependably. Any suggestions?
Reply #1November 12, 2007, 05:12:25 pm
« Reply #1 on: November 12, 2007, 05:12:25 pm »
how's the coolant level?  maybe you have a hg leak?
Reply #2November 13, 2007, 05:11:10 am
Dieseleo
  • 2
« Reply #2 on: November 13, 2007, 05:11:10 am »
coolant level's fine, that's not it.
Reply #3November 13, 2007, 06:26:30 am
saurkraut
  • 904
« Reply #3 on: November 13, 2007, 06:26:30 am »
Might be the temperature sensor.  When they go bad, they read hot.  I just had to change one on my '79.
The sensor is probably located in the spigot on the driver side of the head that the heater hose goes to.
'79 1.6TD RABBIT
'84 1.5TD RABBIT
'83 Diesel Westy
92 Audi 100
'93 Eurovan
'82 Porsche 930
Reply #4November 13, 2007, 09:08:53 am
« Reply #4 on: November 13, 2007, 09:08:53 am »
Probably a fault temp sensor or a bad wire.
Reply #5November 13, 2007, 12:41:19 pm
« Reply #5 on: November 13, 2007, 12:41:19 pm »
as for your heat problem you may need a new thermostat.
