Author Topic: Kobenschmidt AAZ, ALH, AHU Heads Price jump, order now!  (Read 26916 times)
Reply #30November 22, 2007, 08:33:26 pm
starrd
  • 128
« Reply #30 on: November 22, 2007, 08:33:26 pm »
Got my head today
Here it is:
Great service, great price - many thanks BleachedBora
Black 1996 Passat TDI Malone tune, K03/04 Hybrid, Keyless, VR6 Clutch & PP357's
White 1993 Passat TD - GTD nozzles, Keyless - Giles pump, K14, Intercooler, 228mm VR6 clutch & PP, CTN Trans etc
Red 1990 Corrado - custom chip by
Reply #31November 26, 2007, 02:43:36 pm
boostin
  • 17
« Reply #31 on: November 26, 2007, 02:43:36 pm »
What is the build combo for a franken motor guy's?? 1.9 head on a 1.6 block........... :?
I was told by TDIRacing this week, that Dave (PP) can make more power with the IDI's, than can be made with the TDI's.  :o  Man are my ears pointed. I want to hear much more. ( I have a project in mind !!)
89 A2 Jetta restored to mostly original/stock
01 A4 Jetta 133000 w/lots of mod's
84 D50 Mighty Max P/U rice smoker
79 HOT Trans AM, Bandit look-a-like
73 F250  428 CJ  (update.. CJ has left the building)
there are more...
Reply #32November 28, 2007, 11:36:39 am
BleachedBora
  • Administrator
  • 104
    • Cascade German Parts
« Reply #32 on: November 28, 2007, 11:36:39 am »
Quote from: "starrd"
Got my head today
Here it is:
You're very welcome!
Let me know if I can hook you up with a head Boostin, there are still a couple here :).
Cheers,
-BB
'81 CBEA Caddy, '81 DeLorean, '98 Defender TDI, Too many VAG to list
www.cascadegerman.com
Sales and support: [email protected]
Reply #33November 29, 2007, 02:57:03 pm
boostin
  • 17
1.9L head
« Reply #33 on: November 29, 2007, 02:57:03 pm »
Cool BB, I have family in Provo....
which combination ( considering valve/cylinder wall clearance/compression ratio/etc ) is a consideration for the 1.6L block?
there are more...
Reply #34November 29, 2007, 04:21:59 pm
2mAn
« Reply #34 on: November 29, 2007, 04:21:59 pm »
man im so tempted to do this too!!
do u still have any left??
Reply #35November 30, 2007, 03:06:51 am
subsonic
  • 1836
Re: 1.9L head
« Reply #35 on: November 30, 2007, 03:06:51 am »
Quote from: "boostin"
Do a search for Franken, you will gets lots of info.  Basic run down is it is a direct bolt on if you have a hydro block.  If you have the mech block you will need to block off one passage.
Benefits include larger valves, more free flowing designed ports, and a reduction in compression ratio.  If you install 1.9TD injectors you will get the additional benefit of "dual stage" injection.  Combine this with the metal head gasket and you will have a setup that should allow you to run more fuel at greater boost.  This means more power.
Add the 3" Down pipe for 300 bucks, Mod your IP following the directions in the FAQ section and away you go.
Of course an intercooler will help greatly as would a IP rebuilt by Giles or Tintin.
Hope this helps.  Jim
Reply #36December 04, 2007, 03:28:25 pm
BleachedBora
  • Administrator
  • 104
« Reply #36 on: December 04, 2007, 03:28:25 pm »
Sorry I've been away at a family reunion guys! Thanks for the explanation Jim! I've had several people interested in the remaining heads I have, but no takers yet, still two up for grabs at the group buy price!
Cheers,
-BB
Reply #37January 07, 2008, 11:19:30 am
BleachedBora
  • Administrator
  • 104
« Reply #37 on: January 07, 2008, 11:19:30 am »
Just ordered in a couple more :).
Hope everyone had a great holiday season,
-BB
Reply #38January 13, 2008, 10:16:03 pm
Helliouse
  • 164
« Reply #38 on: January 13, 2008, 10:16:03 pm »
Do you still have the AHU head?
And is it True that Dave can make more HP with IDI?
1990 Jetta TD...Its a Project! And wait...its built in Wolfsberg! swEEt - 1.6l TD = Dead... TDI ALH in the works...
Reply #39January 14, 2008, 06:20:10 am
subsonic
  • 1836
« Reply #39 on: January 14, 2008, 06:20:10 am »
There are a few members who are pushing big HP out of the IDI.
635Racer
Malone
Andy2
Over in Europe we have members running high HP as well,  I just have'nt had my coffee yet and am pulling a brain cramp as to the names.
BB,
Are you finding more of a market for the AAZ heads now that the 1.6/1.9 Franken engine combination  info is out there?
Reply #40January 14, 2008, 08:46:37 am
Helliouse
  • 164
« Reply #40 on: January 14, 2008, 08:46:37 am »
Well i looks like it comes down to pistons, and it sound like some one is working on them.
I guess the question i will have to pose, obviousely not in this form, is the potential power difference.
Thanks for the Info.
Reply #41January 15, 2008, 08:17:18 pm
Critchie
  • 4
« Reply #41 on: January 15, 2008, 08:17:18 pm »
interested in head, wondering if you can get new aaz short blocks, injector pumps, and lines also
Reply #42January 16, 2008, 08:34:14 am
subsonic
  • 1836
« Reply #42 on: January 16, 2008, 08:34:14 am »
Send him a email at [email protected]
Reply #43January 31, 2008, 11:15:32 pm
BleachedBora
  • Administrator
  • 104
« Reply #43 on: January 31, 2008, 11:15:32 pm »
Oops! Just saw this.
I do have some other AAZ products:
-1.9 AAZ Long Block --- $2999+shipping
-Complete 1.9L engine in 1.6L drop in configuration --- $4395+shipping
-1.6L-1.9L conversion kit --- $2999+shipping
-1.9L Turbo and non turbo short blocks --- $2350+shipping
-Vanagon PD 150 conversion kit (complete with wiring, ECU everything) --- $11995+shipping
-1.6L injection lines (set) --- $149 shipped
Also:
New transmissions that will fill the Jetta AHU TDI model.
Most of the US cars came with a CTN code these are euro code ASD. Same
Ring and Pinion and a .72 5th. $1295
PN: 02A 300 044 LX
Cheers,
-BB
Reply #44February 09, 2008, 09:20:30 am
hillfolk'r
  • 1532
« Reply #44 on: February 09, 2008, 09:20:30 am »
Quote from: "subsonic"
that i will........ but just in case...i need an ahu head  still got any???????
Throttle cables ftw
