Author Topic: 1.9 camplate or bigger plunger timing question  (Read 2000 times)
October 28, 2007, 10:44:58 am
rallydiesel
  • 1880
« on: October 28, 2007, 10:44:58 am »
If you put a 1.9 IDI camplate or a larger plunger in a 1.6 IP, do you have to time it to a different value or is it still ~1.00mm?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1October 28, 2007, 05:13:20 pm
andy2
« Reply #1 on: October 28, 2007, 05:13:20 pm »
With the higher lift camplate (1.9td) the timing will still be set the same as the 1.6 one beacuse the start of injection will happen at the same point of either ramp.
Bigger plunger does affect timing but only when you take a big step from say 9 to 12mm I backed off my timing a bit mabye .10 mm at most.
Reply #2October 28, 2007, 05:45:28 pm
rallydiesel
  • 1880
« Reply #2 on: October 28, 2007, 05:45:28 pm »
OK, thanks.
