Author Topic: trans part swapping?  (Read 5288 times)
March 05, 2005, 02:06:23 pm
Hammy
  • 169
« on: March 05, 2005, 02:06:23 pm »
Is it possible to swap out the ring and pinion gear from a CHE to an AWY?
Thanks
Hammy (Jason)
'96 Golf, 1.8 gas
'91 Golf, 1.6 TD
'98 GMC 1500 4x4, 5.7L (doing my best to save the oil companies, 85 liters takes me 600 km)
'78 Ford 3000 3cyl, 201 diesel, with loader
Reply #1March 08, 2005, 05:31:00 pm
racer_x
  • 123
Re: trans part swapping?
« Reply #1 on: March 08, 2005, 05:31:00 pm »
Quote from: "Moonstone"
Thanks
If you are looking for a 3.667:1 ring and pinion for your AWY, you should try to get one from a 1.8L 8v transmission.
The 16V transmissions (AGB/2Y) and the 2.0L ABA transmissions (AMC, CHE, DFQ) use a different 4th gear and a different pinion shaft. Your 4th gear set won't fit on the pinion shaft from the CHE. The hole in the middle of your gear is smaller than the shaft from the CHE.
But if you want to put the ring and pinion from the CHE, along with the 4th gear set and 5th gear set from the CHE into your AWY, that would work. And that would give you taller 4th and 5th gear sets, which would lower engine speed for highway driving.
