Author Topic: will a 1.6 timing belt cover work on 1.9 aaz?  (Read 2684 times)
October 19, 2007, 08:43:22 pm
vixentd
  • 88
« on: October 19, 2007, 08:43:22 pm »
Needing a timing cover for a 1.9 aaz in Vancouver b.c.  Any one know if a 1.6 will work? Anyone have a 1.9? Thanks
Reply #1October 20, 2007, 08:03:00 am
roland
  • 1
« Reply #1 on: October 20, 2007, 08:03:00 am »
no it doesnt fit, Ive had both engines and tried fitting the timing belt cover from the 1.9 to the 1.6...no dice
Diesel, because real cars don't need spark plugs
Reply #2October 21, 2007, 08:31:47 pm
janb
  • 167
« Reply #2 on: October 21, 2007, 08:31:47 pm »
I use the metal ones off early 1.6's, it takes a little 'tuning' as you need to weld a tab onto the center mount bracket and add a hole 16mm higher, then trim off some of the area on cover under the inj pump.  Then some creative hammering to open that area up a bit (directly under the IP)
The Stealth Rabbit
VW-d's are forever
