Author Topic: Possible to replace strut bearings on a2?  (Read 5552 times)
October 17, 2007, 04:54:32 am
trent77
  • 217
« on: October 17, 2007, 04:54:32 am »
Just want to double check the service manual. I just need to remove the top nut and drop the strut down and replace the bearing right? Just want to make sure the strut will not fire a spring off at me. thanks for your help.
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1October 17, 2007, 07:51:11 am
rallydiesel
  • 1880
« Reply #1 on: October 17, 2007, 07:51:11 am »
No, you need to compress the spring. I did mine this year and almost shot a spring at my head because I thought I didn't need to compress the spring.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2October 17, 2007, 10:31:13 am
« Reply #2 on: October 17, 2007, 10:31:13 am »
my springs didn't shoot at me.  maybe they were bad?  :lol:   the lowering kit i had was so easy to put on... no need for spring compressors :)
Reply #3October 18, 2007, 09:17:44 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #3 on: October 18, 2007, 09:17:44 am »
I managed to get mine off without using the spring compressors, but had to compress them to get everything back together.   They jumped a little when removing them, but it was ok because I knew they would and had them aimed in a safe direction.
Calvin
91 VW Golf 1.6NA 5spd
Reply #4October 22, 2007, 03:21:02 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #4 on: October 22, 2007, 03:21:02 pm »
Do I get an Honourable Mention in this years Darwin Awards for using polypropelene rope to bind up the spring? 500lb's of compressed rage sounds like fun in my little garage. :D
Reply #5October 23, 2007, 06:27:31 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #5 on: October 23, 2007, 06:27:31 am »
I believe that the requirements for honorable mention involve blood.   :lol:
Calvin
Reply #6October 23, 2007, 03:34:20 pm
mainer
  • 126
« Reply #6 on: October 23, 2007, 03:34:20 pm »
I wouldn't even thing about pulling a front spring off with out compressing it first. Thats just crazy. It is a good way to get hurt.
_________________
Mercedes W125 Rekordwagen
01 Jetta
84 Jetta TD
08 Duramax
12 Sportwagen TDi
Reply #7December 13, 2007, 08:16:06 pm
mk2diesel
  • 60
« Reply #7 on: December 13, 2007, 08:16:06 pm »
and slip a chain thru the coils just to be on the safe side  .. you're gonna need the special tool to remove the knotched nut that holds the bearing in place ( ground down spark plug socket with 2 fingers sticking out...)
Reply #8December 13, 2007, 11:56:07 pm
Op-Ivy
  • 513
« Reply #8 on: December 13, 2007, 11:56:07 pm »
Quote from: "mainer"
Agreed.
Reply #9December 14, 2007, 07:22:42 pm
trent77
  • 217
« Reply #9 on: December 14, 2007, 07:22:42 pm »
this job has long since been done. I was able to rent the spring compressor, and as for the special nut, i just had to tap on it with a punch, then thread it with my fingers. thanks for the info.
77 westfalia
06 GMC Duramax
