Author Topic: what to take from a A3 TDI?  (Read 3272 times)
October 15, 2007, 09:53:41 am
slorimer
  • 52
« on: October 15, 2007, 09:53:41 am »
I have a 94 AAZ and I may have access to a 97-99 TDI for parts.  Are there any particular parts I should grab to upgrade my car.  So far I'm thinking wheels, alternator (cluthed) pulley, maybe crank pulley.  Anything else useful.  Are the seats in the TDI's better, any other engine parts worth taking?  I'm fairly new to Jetta's and diesels but I've been reading a bit.  TIA
94 1.9TD
Reply #1October 15, 2007, 10:37:37 am
vwmike
  • 1158
« Reply #1 on: October 15, 2007, 10:37:37 am »
If I were you I'd be looking to take the whole engine, trans, wiring, ecu, cluster, steering knuckles, front brakes....everything else is secondary.
Reply #2October 15, 2007, 07:41:44 pm
CoolAirVw
  • 175
« Reply #2 on: October 15, 2007, 07:41:44 pm »
Leave the radiator cap and take everything else.
(on 2nd thought you may need the radiator cap someday)
85 Jetta Turbo Diesel
75 Porsche 914
93 GMC Truck
99 Caravan <--wifes gotta drive something :)
Reply #3October 16, 2007, 02:18:53 am
rabfan
  • 28
« Reply #3 on: October 16, 2007, 02:18:53 am »
I don't think the crank pulley from the TDI will fit on you AAZ without modification to the crank end. That's the rumor i hear anyway......
Reply #4October 16, 2007, 06:55:11 am
slorimer
  • 52
« Reply #4 on: October 16, 2007, 06:55:11 am »
Agreed, I was planning for the TDI pulley crank mod at some point, that's why.  Thanks for the responses, sounds like those cars/engines are golden.
94 1.9TD
Reply #5October 16, 2007, 08:23:41 am
myke_w
  • 1099
« Reply #5 on: October 16, 2007, 08:23:41 am »
take the drive train and wiring harness, put it on a pallet and send it to me :)
Reply #6October 16, 2007, 03:33:59 pm
Black Smokin' Diesel
  • 656
« Reply #6 on: October 16, 2007, 03:33:59 pm »
I would grab the front brakes (spindle, calipers, carriers...) and install them on your 94. I don't know where you are located but early canadian MK3s had the same brake setup as MK2, 9.4" brakes. Later MK3s had 10.1" brakes.
