Author Topic: what are this sensor for?  (Read 4235 times)
October 14, 2007, 04:29:04 am
carrizog60
  • 978
« on: October 14, 2007, 04:29:04 am »
i know the first one is for temp. gauge on dash but what about the other 2?
one is problably for glow plug relay but wich one?
asking because my glow plug light wasnt working and after switched wires now it works...
blue/white wire is now on the sensor located on the hose that goes to heater core.
because the engine was opened i dont know if this is the right location...
JK engine converted to the dark side :lol:
Portugal
Reply #1October 14, 2007, 08:57:50 am
Greasecar
  • 126
    • http://www.greasecar.com
« Reply #1 on: October 14, 2007, 08:57:50 am »
The one on the back of the cylinderhead is oil pressure, the two on the ports are coolant temperature and the wires are interchangable.
www.greasecar.com
79 Mini diesel (1.5 Peugeot)
82 rabbit TD (given to Junkcollector Jay)
84 rabbit TD (intercooled w/ VNT)
82 rabbit PD (undergoing swap)
01 Golf TDI (burned to the ground)
02 Golf TDI (355,000 miles and counting)
04 Passat TDI Wagon (Grocery getter)
Reply #2October 14, 2007, 10:08:21 am
carrizog60
  • 978
« Reply #2 on: October 14, 2007, 10:08:21 am »
thank you.
do you know if the wires are in the correct place?
this way the glow plugs work...
 :oops:
Portugal
Reply #3October 14, 2007, 11:48:36 am
dokarex
  • 61
« Reply #3 on: October 14, 2007, 11:48:36 am »
Hi
Does your temp gauge work?
Those two senders are for the glow plugs and the temp gauge.
I don't think it matters which is where. The senders work as a ground when the coolant closes the circuit and they are quite cheap to replace.
D
1987 1.9TD Doka from Germany gasser DU tranny, fuel turned up, 1.6 LDA pin, boost at 15 psi,egt and boost gauges,stock diesel tach,air filter behind passenger tail light, IC to come
2005 Jetta Wagen TDI
B6200 Kubota Diesel
16ft Freestyle catermeran
16ft Sunray 85HP
Reply #4October 14, 2007, 12:59:57 pm
carrizog60
  • 978
« Reply #4 on: October 14, 2007, 12:59:57 pm »
yes it works.
it is conected to the sensor in front of the engine(first pic)
the doubt was on pic number 2 and what sensor were those...
so,correct me if i am wrong, upper sensor is oil pressure and lower sensor is for glow plug relay right?and the wires are conected in the right spot?
Portugal
Reply #5October 14, 2007, 03:49:23 pm
« Reply #5 on: October 14, 2007, 03:49:23 pm »
picture number 2 is of the oil pressure sensor on the side of the head. I think if you unplug it when the car is running the low oil pressure light/buzzer will come on.
Reply #6October 14, 2007, 05:26:28 pm
westcoaster
« Reply #6 on: October 14, 2007, 05:26:28 pm »
Quote from: "Greasecar"
While the wires may be interchangable and they are both the same sensor, would you not be getting different readings depending on what sensor you are plugged into?
I would think the sensor on the side of the block would read cooler than the one on the back of the block (below the oil pressure switch) as you would be reading the coolant temperature coming from the radiator rather than coming out the back of the head.
'87 suzuki samurai with a 1.9 AAZ TD transplant
Reply #7October 14, 2007, 05:50:52 pm
Greasecar
  • 126
« Reply #7 on: October 14, 2007, 05:50:52 pm »
The temps between the two would not be significantly different since they are both in the coolant stream of the cylinder head, some vehicles have both of them located on one coolant port.  The sensor for the GP relay only comes into play when the car is started (only turns the GPs on when the signal is below a certain value).
www.greasecar.com
Reply #8October 14, 2007, 06:51:52 pm
westcoaster
« Reply #8 on: October 14, 2007, 06:51:52 pm »
Quote from: "libbybapa"
Quote from: "westcoaster"
The coolant from both flanges is leaving the head on it's journey to the waterpump.  On the end of the head it goes through the heater circuit.  The other circuit is to the top of the radiator.  The temp difference will be very slight if any.
Andrew
This has me a little confused then...
Rather than hijack this thread any more I'll start a new one....
Reply #9October 15, 2007, 01:43:55 am
carrizog60
  • 978
« Reply #9 on: October 15, 2007, 01:43:55 am »
but re the wires well connected now?
thats what i also need to now...
because at the shop they put the white/blue on top(oil pressure?) and i have switched them...
Portugal
Reply #10October 15, 2007, 09:57:56 am
« Reply #10 on: October 15, 2007, 09:57:56 am »
Quote from: "burn_your_money"
Do this test and you will know
Reply #11October 15, 2007, 10:54:36 am
carrizog60
  • 978
« Reply #11 on: October 15, 2007, 10:54:36 am »
do you believe that i didnt see your post? :oops:
going to check it, thanks :wink:
Portugal
Reply #12October 16, 2007, 12:32:55 pm
carrizog60
  • 978
« Reply #12 on: October 16, 2007, 12:32:55 pm »
nothing happened...
i just need to be sure whatwire is to what sensor...
Portugal
Reply #13October 16, 2007, 03:18:35 pm
ELVIS
  • 51
« Reply #13 on: October 16, 2007, 03:18:35 pm »
if it is same wiring loom/colours as a vanagon
 blue/black is to the oil sender
blue/white is to coolant sender
the red/yellow in top pic is same aswell
if you take off the red/yellow and ground it to the block the auxilliary water pump should start :D
Reply #14October 17, 2007, 02:39:28 am
carrizog60
  • 978
« Reply #14 on: October 17, 2007, 02:39:28 am »
have 3 wires:
yellow/red, blue and white/blue
Portugal
