Author Topic: Possible to lower seat?  (Read 4640 times)
October 13, 2007, 07:48:52 pm
subsonic
  • 1836
« on: October 13, 2007, 07:48:52 pm »
OK, I am 6'4".  I only wear a 33-34" length pants.  I have a long body.  Is there any way to lower the driver seat an inch or two?  I have no sunroof so I am at maximum roof height right now.  I fit, but it's tight.  Kind of need to crank back the seat low rider style.
So short of welding a half dome over the drivers side, any suggestions??
Reply #1October 14, 2007, 12:18:33 pm
BlackTieTD
  • 1512
« Reply #1 on: October 14, 2007, 12:18:33 pm »
scirocco and corrado seats are a direct fit (the adjuster might need messing with but the slider and secure pin will all work)....and they are height adjustable. and have much better bolsters.
Reply #2October 14, 2007, 01:17:21 pm
blkboostedtruck
  • 1535
« Reply #2 on: October 14, 2007, 01:17:21 pm »
Yep Corrado seats work well! I used a set in my caddy and it gave me more head room!
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #3October 14, 2007, 01:38:27 pm
subsonic
  • 1836
« Reply #3 on: October 14, 2007, 01:38:27 pm »
I did not know that.  Thanks.
GO
PATS!!
Reply #4October 14, 2007, 06:07:12 pm
« Reply #4 on: October 14, 2007, 06:07:12 pm »
Most mk2 seats have the height adjustment as well.
You are basically the exact same height / leg length as me Jim and I didn't have any problems in my 92 jetta with stock seats.
Reply #5October 14, 2007, 07:35:32 pm
subsonic
  • 1836
« Reply #5 on: October 14, 2007, 07:35:32 pm »
My seats are not height adjustable.  Front back and tilt.  thats it.  They are stock Golf GL seats, vintage '85.  Nice shape, not a tear in them.
I fit, but like I said it's a bit tight.  :shock:  :lol:   Wife was reading over my shoulder on that one.  She smirked and gave me a pinch. :lol:
When I get out of the car I almost always end up with my hair squished flat on top.  Kind of gives me the nice block head look. :)
Reply #6October 14, 2007, 07:48:06 pm
« Reply #6 on: October 14, 2007, 07:48:06 pm »
Quote from: "subsonic"
Pictures?  :lol:
Reply #7October 15, 2007, 09:46:02 am
BlackTieTD
  • 1512
« Reply #7 on: October 15, 2007, 09:46:02 am »
you can also use a height adjust base, and cover it with your current seat material if you have a nice all-matching interior.
Reply #8November 13, 2007, 11:33:37 pm
Quantum TD
  • 1195
« Reply #8 on: November 13, 2007, 11:33:37 pm »
Quote from: "BlackTieTD"
Yeah. It's not too bad to do. I do this mod on all the Rabbit's that I sell. I'm a big guy too, and I drive the cars I sell before they go. In an effort to keep the stock look, but add a bit of legroom, I pull the bases off of 1985-1988 Wolfsburg Jettas with the adjust lever.
Swapping the lower cushion cover takes about 1/2 hour. If you use Jetta bases, you'll have to pull the cover off the original lower foam and swap. Then reassemble.
Good Luck
