Author Topic: overtightened belt VS. premature IP bushing failure  (Read 9807 times)
Reply #15October 24, 2007, 10:05:14 am
Black Smokin' Diesel
  • 656
« Reply #15 on: October 24, 2007, 10:05:14 am »
Must have been stuck pretty good to break the cam nose :?
Reply #16November 12, 2007, 12:25:17 pm
« Reply #16 on: November 12, 2007, 12:25:17 pm »
Ok, so I was gonna get a used cam from my Uncle untill I discovered I can get one new for $100 from TOP LINE, that's the place that made my head. I just found out that they still make heads complete or bare for rabbits, jettas, fox, quantum and a bunch of audis and every other car out there. Oh yeah, it's also the same cam for hydro and solid lifters, weird uh. They got free catalogs and CDs that you can get from they're website.
Reply #17November 12, 2007, 02:01:51 pm
« Reply #17 on: November 12, 2007, 02:01:51 pm »
what is their website?
Reply #18November 12, 2007, 02:11:32 pm
« Reply #18 on: November 12, 2007, 02:11:32 pm »
www.toplineauto.com
They don't have my cam in stock and they don't when they'll have it. They make em' so I thought it'd be easy to get one. :x
Reply #19November 13, 2007, 12:53:42 pm
« Reply #19 on: November 13, 2007, 12:53:42 pm »
I had a brainstorm last night at like 1am. When I got my rabbit the head was cracked so I bought a brand new one w/ a cam and I finally remembered it. So I looked and it has rust on some of the lobes and only light pitting on one or two. One lobe has a small pit right on the tip. Does anybody know if this is usable?
Reply #20November 13, 2007, 12:57:53 pm
« Reply #20 on: November 13, 2007, 12:57:53 pm »
:cry: I think it's no good :x
Reply #21November 13, 2007, 03:02:32 pm
Baxter
« Reply #21 on: November 13, 2007, 03:02:32 pm »
Quote from: "myke_w"
we suspected a bent bracket once, we were wrong.. man, that thing is so thick, you'd have to heat it to bend it in the vice, it' also has that curved edge which adds a boatload of strength, show me a bent bracket from normal use, I'll show you a flying pig (or a flying vanagon maybe)
Will a flying T4 do !!??
(Eurovan)
http://www.youtube.com/watch?v=hggBHD3aFxA
Reply #22November 14, 2007, 01:21:59 pm
« Reply #22 on: November 14, 2007, 01:21:59 pm »
I found a place that grinds cams, bought a reground one for $50.
www.oregoncamshaft.com
Reply #23November 27, 2007, 02:43:48 pm
« Reply #23 on: November 27, 2007, 02:43:48 pm »
what a pain it is getting valve shims, ordered some from napa and all came except the 3.65mm ones. :x . So I'm still waiting for parts and hitchin' rides. :roll: . I should be rollin' this week though, I've been down for over two months now. :cry:
Reply #24November 27, 2007, 03:16:06 pm
subsonic
  • 1836
« Reply #24 on: November 27, 2007, 03:16:06 pm »
Quote from: "Mr Brick-Yard"
(Eurovan)
I found this file photo of the drivers used in this video.
[/img][/url]
Reply #25November 29, 2007, 01:08:37 pm
« Reply #25 on: November 29, 2007, 01:08:37 pm »
I have a question. Has anyone been so scared of overtightening the t-belt that it slipped because it was to loose? I wonder how loose it can be without jumping a tooth. Needless to say, I'm kinda worried about it.
thanks
Reply #26November 29, 2007, 01:13:31 pm
« Reply #26 on: November 29, 2007, 01:13:31 pm »
if you can twist it 45-90 degrees between the pump and the cam you are good. 45-60 is ideal I think.
Reply #27November 29, 2007, 01:34:00 pm
« Reply #27 on: November 29, 2007, 01:34:00 pm »
wow, fast reply. Yeah, I always had a hard time goin' by that 'cause if you twist hard enough it'll go further than that easy. So this is like with thumb and forefinger and weak twisting? not channel locks :lol: My last IP got rebuilt under warranty but I had to pay because I didn't use a gauge so they assumed the belt was to tight. thanks a lot :D
Reply #28November 29, 2007, 01:36:58 pm
« Reply #28 on: November 29, 2007, 01:36:58 pm »
yeah relatively easy. Light pressure... It's hard to describe but most people would be able to hold it there for extended periods of time without getting tired. They'd get bored before they got tired or sore hands.
Fast reply because I'm procrastinating going to work :P
Reply #29November 30, 2007, 06:01:09 pm
« Reply #29 on: November 30, 2007, 06:01:09 pm »
I started it today!!! It ran terrible and knocked loud so I thought the belt slipped but it didn't it was just firing way to soon. I forgot how gutless it is, man, it's like 0-60mph in 3 minutes 8). Now all I have to do is fix the heater and I'll be good to go. :)  Thanks everybody!!!
