Author Topic: Bubbling around injector  (Read 7284 times)
October 09, 2007, 04:43:55 am
bvolks73
  • 183
« on: October 09, 2007, 04:43:55 am »
One of my small return lines between the injectors was leaking yesterday and I noticed bubbles coming out between the injector and the head where the diesel was leaking down. Is that a bit of compression leaking by the heat shield?
1985 TD Jetta coupe
1995 Golf CL
1971 VW Doublecab
1999 Corolla
2005 Sx 2.0
2007 Yaris
Reply #1October 09, 2007, 05:14:43 am
« Reply #1 on: October 09, 2007, 05:14:43 am »
usually it is only the diesel boiling off. Replace the leaky line and go from there
Reply #2October 09, 2007, 10:30:13 am
Doug
« Reply #2 on: October 09, 2007, 10:30:13 am »
Sometimes they do seem to leak a bit, maybe because the threads are stretched. Try some teflon tape on the injector threads carefully installing the injector so that the tape stays where it is supposed to stay. There are other thread sealants that resemble grease but I have not had any experience with them on the car engine. They are commonly used in industry to seal high pressure assemblies.
Reply #3October 11, 2007, 11:00:14 pm
  • 2932
« Reply #3 on: October 11, 2007, 11:00:14 pm »
I've seen several reasons for leaks around the base of the injector.
 Once it was a piece of sand on the heat shield,... another time it was a knick on the heat shield,... another time it was a rough surface on the part of the head the heat shield sits on.
 I check all this real well before installing injectors now.
 I took a long bolt, thin enough to fit through a heat shield, shoved that bolt through a piece of emery cloth, then through the heat shield,... a nut on the back to hold the emery cloth against the heat shield, then I trimmed the emery cloth.
 This was a tool idea I got from Andrew and I use it to clean up the head surface that the heat shield sets on.
 If you haven't been playing with your injectors, I'm not sure why they would suddenly start to leak.... maybe the previous owner reused the heat shields.
 Thanks for posting this in the troubleshooting section.
Reply #4October 23, 2007, 11:12:48 pm
neimis
  • 75
« Reply #4 on: October 23, 2007, 11:12:48 pm »
Quote from: "fatmobile"
Do you do this with the head still on the block? I would really hate to have the loose abrasive particles from the emery cloth ending up inside my cylinders....! I don't think that would be too good...
'92 Passat TD
'01 Golf TDI
'15 Golf TDI
Reply #5October 25, 2007, 12:21:18 am
  • 2932
« Reply #5 on: October 25, 2007, 12:21:18 am »
The pieces are small enough that I'm not worried about it.
If you are worried about it, you could remove the head,... or try used emery cloth and wet it.
 Or maybe you can figure out another way to surface the seats without anything falling into the cylinders.
