Author Topic: R134 A.C. or No??  (Read 15134 times)
October 08, 2007, 03:15:18 am
Ziptar
  • 565
R134 A.C. or No??
« on: October 08, 2007, 03:15:18 am »
The Eco I bought has been converted to R134, the 89 Carat I am swapping in to is R12.
Neither system works currently..
Should I swap over the R134? If I do do I need everything?? including the condensor and stuff under the dash?
I have heard that R134 conversion aren't maybe always so good.. Not as cold and don't last as long.
Reply #1October 08, 2007, 10:39:02 am
cyrus #1
  • 360
R134 A.C. or No??
« Reply #1 on: October 08, 2007, 10:39:02 am »
I'm not sure what the laws look like in Florida but here it's illegal to charge an R-12 system.  If that's the case for you as well, you will have to convert to R-134.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
1990 Jetta 8v-Eventually to be 1.6TD
Reply #2October 08, 2007, 06:59:03 pm
Ziptar
  • 565
R134 A.C. or No??
« Reply #2 on: October 08, 2007, 06:59:03 pm »
Shops can still charge R12, they couldn't for a while but law was changed a couple years back. It's spendy though. Last time I had a pound added to my wife's old Volvo before we traded it, a pound was $48.
Average Joe can't buy R12 though.
Reply #3October 09, 2007, 12:41:43 pm
R134 A.C. or No??
« Reply #3 on: October 09, 2007, 12:41:43 pm »
just switch over to duracool or redtek.  no retrofit necessary, except you might want to change some of the o-rings.  i also recommend changing the receiver drier.
r134a will slowly kill your a/c compressor if you don't switch it to the synthetic oil, and r12 will probably last a while, but then leak into the atmosphere and stay there for a hundred years destroying the ozone layer.
duracool might leak, but its pretty cheap and you can top it off yourself eliminating the 'middle-man'
Reply #4October 10, 2007, 02:20:01 am
Ziptar
  • 565
R134 A.C. or No??
« Reply #4 on: October 10, 2007, 02:20:01 am »
Nice jtanguay, Thanks,
I read a long thread about Duracool and Redtek on TDI club.
Duracool is the way to go I think, I like the price that's for sure. I had heard there were "Alternatives" out there but, the phrase "are illegal and explode" always seem to be attached. Turns out neither is true, well they explode but, they all do when under pressure and mixed with oil and is none is any  worse then the fuel in the fuel lines.
Ok, since I am swapping parts around anyways I'll get an O-Ring kit and redo them while I am swapping and a receiver drier, $32 at Arizona AutoHaus.  Does R12 or R134 matter for the O-Rings?
Beyond that does it matter which cooling parts I use or can I just mix and match stuff between the R12 and R134 systems?
Thanks,
Reply #5October 14, 2007, 03:33:30 pm
R134 A.C. or No??
« Reply #5 on: October 14, 2007, 03:33:30 pm »
Quote from: "Ziptar"
Thanks,
you can mix and match with duracool.  all i recommen doing is blowing out the lines with something like nitrogen or even an a/c cleaner (some sort of device that blows an evaporating solvent through the line).  what this does is get rid of the corrosive oil that's been sitting in there.  the oil is hydroscopic meaning it absorbs moisture and turns acidic, and pits the lines/compressor parts.  you can just leave it in and it might not do much, but if you have time/patience, its not bad preventative maintenance.
for the oil, go with duracool's a/c oil chill.  its miscuous meaning it stays in the compressor where it is needed most, and isn't hydroscopic, meaning it won't go acidic from moisture.  plus it has a nice green colour to detect leaks around fittings.
if you don't have access to a vacuum for the a/c system, buy duracool's dura dry.  it turns moisture into a synthetic lubricant in the system.  pretty neat!
i also recommend getting one of those tire valve tighteners.  they work well in tightening the old style a/c valves.  the new r134a style are skinnier though so it won't work for them.  the most common leaker is the high side valve.  tighten that thing and you should be good to go.  most garages have their gauges hooked up to the ports when they run the tests, and the system shows NO leakage, so then off you go with a nice topped up system.  meanwhile its leaking from the valve... the cap does hold a little bit, but not much; maybe a few psi at best?
good luck :)  i've charged my system about a year ago and it still works!  not very cool in the summer, but i need to fix my fan duct cowling to increase airflow over the condensor (if you don't remove the heat, the system is not efficient)
Reply #6December 14, 2007, 03:13:48 am
Ziptar
  • 565
R134 A.C. or No??
« Reply #6 on: December 14, 2007, 03:13:48 am »
Quote from: "jtanguay"
I have been thinking the same thing. I have a dual Fan setup from a A2 G60 or Passat 16V on the way, arrives  today. Should bolt right up in place of the single fan, I'll need to change the plug though. Should great for hot days and A/C Season.
I'll be charging my A/C soon and was doing more googling....
Found a really detailed R12a HC Refrigerant post on aircondition.com
Reposting it here for posterity....
Posted by Jungle Eddy on August 12, 2001 at 22:24:33:  via: or 66.25.151.188
Repost + More info:
Over the past 1 ½ years one of the shops I own has charged over 132 passenger cars and trucks with hydrocarbon refrigerants, mainly using Envirosafe ES12a. I have been watching this forum for quite some time, and thought it was about time I posted something.
We have had nothing but the best of experiences with hydrocarbon refrigerants. Here in the south it is HOT! Over 100 on a regular basis. The ONLY time we have found insurmountable difficulties is when trying to service vehicles with dual A/C units. This problem SEEMS to have been resolved with the new “industrial” version of ES12a. We have found that the hydrocarbon refrigerants do not cool as well as the Freons at idle speeds; although, usually acceptably well. The worst offenders are older R12 systems. This is due to the expansion valve/orifice not being truly calibrated for these chemicals; and (theoretically) the heat produced in the condenser when using these types of refrigerants. We DO NOT add any additional propane to any of our installs. (No problems with that, just stated for reference.)
First, the facts:
FACT: If your compressor has locked up or worn out, you now have metal particles inside your A/C system. In these cases you MUST disassemble the system so that all tubes can be flushed. This means that you must remove the expansion valve/orifice tube to allow the flush to flow through the system. While it is out it would be silly not to replace it!! You also need to replace the accumulator since it probably has the largest deposit of crap inside its UNFLUSHABLE walls.
FACT: If your system oil smells burned or is discolored in any way the above flush and clean also applies.
FACT: ANYTHING inside the system that can either PARTIALLY or completely clog the exp valve/orifice needs to be removed BEFORE you complain that your system is not cooling properly.
FACT: Unless you are using the OEM recommended refrigerant for a system there is no way to know in advance the exact amount of hydrocarbon blend refrigerant that will correctly charge your system. This fact is born out of experience. Even if you do know the exact amount of refrigerant that your system will need, it is difficult to measure it out without an electronic scale and a 30 lb bottle. It is really difficult to get ALL the refrigerant out of the small cans! The BEST charging method is using temperatures and pressures.
FACT: The GREAT majority of A/C systems I have seen have no trouble hitting vent temps in the low 40’s while the vehicle is moving in 90-92 deg ambient air. Of course, only when serviced then charged correctly.
FACT: If your system is not cooling properly because it is low on refrigerant, you have a leak!!
FACT: 80% of the time the leak in the system is one of the charge valves! For $1, replace them both while you have the system open!! Replacing the caps with new ones is also recommended since they will also have new seals in them.
If, as an individual, you are charging an A/C system that has a known slow leak and plan on using a hydrocarbon refrigerant you may run into several problems. 1. During the periods when the A/C system is NOT in use, it is POSSIBLE for only ONE PART of the refrigerant mix to leak out of your system and leave you with an improper mix ratio of propane to isobutane; this can cause reduced cooling and the inability to get the system back to full efficiency without a full suck and recharge. 2. If the slow leak is anywhere on the high-pressure side of the system, there is a GOOD chance that during previous or current use that part of your oil supply leaked out with the refrigerant. Oil level in an A/C system is CRITICAL to BOTH the preservation of your compressor AND the proper cooling balance between low and high rpm use! The oil in an A/C system actually mixes with the refrigerant and is carried through the system continuously when in use. This means that it is pushed through your expansion valve/orifice tube continuously as well. Too much oil can restrict flow at high rpm causing a low low side and a high high side. Too little oil can cause pressures at idle speed to be too high on the low side and too low on the high side. You can “fool” any system into cooling somewhat at a SPECIFIC rpm when the oil level is wrong, BUT, all other rpms will produce really poor cooling. Compressors and systems are designed for a specific oil volume. SOME systems are designed for as little as 4 oz of oil. If one of these systems loses just 1 ounce of oil the system is 25% low on oil! Imagine how your body would perform if it was 25% low on blood! The margin for a correct oil level is small. What I am saying here is that a CORRECT oil charge is CRITICAL to getting those 40 deg vent temps in 95 deg weather! AFTER FLUSHING THE ENTIRE SYSYEM make sure that when consulting a manual or a dealer that you ask for the TOTAL system oil capacity. Otherwise I have found that 90% of the time they will quote you the capacity for the compressor by itself!!! Pouring the oil out of your old compressor and measuring it ONLY works if the entire system is/was completely and correctly full of oil!!! It is our experience that about 18 of 20 vehicles we disassemble are either low on oil from leakage, or over filled by a previous technician. Once again, the correct oil level in an A/C system is critical to proper cooling. You cannot be sure your oil level is correct without flushing the system and refilling it PROPERLY. YES IT REALLY DOES MATTER! (regardless of refrigerant type)
Hydrocarbon refrigerants and the vacuum. Do you need to pull a vacuum to charge a system? You decide. You need some way of getting all of the old refrigerant out of the system, especially if it was a “Freon”. “Freons” do NOT like air in ANY quantity. Any air/Freon in the system together will cause corrosion and future issues. A “hard” vacuum is one way of insuring that your newly charged A/C system is free of the possibility of any air mixing with any left over Freon. Charging with a hydrocarbon refrigerant into either a 10” vacuum or a zero vacuum does not affect the cooling dramatically (2-5 degs), BUT it DOES affect your high side pressure greatly. If you charge with air in the system you can see high side pressures equal to or exceeding straight R12. Higher pressures mean more work for your compressor. In our experiments with a fleet of three cylinder Geo Metros, the drivers, (all R134 to ES12a conversions!) FAR preferred to drive the cars with A/C’s that had been charged under a hard vacuum because they had more “pep” than the ones charged at zero vacuum. The difference in the amount of horsepower needed to run the compressors was enough that anyone could feel the benefits! Getting a “correct charge” with a hard vacuum can be more difficult than when air is in the system for a technician who is used to reading pressures with R12 or R134. You simply have to pay closer attention to your temperatures since the high side pressure may not be where your experience tells you it should be. We charge all our vehicles under a hard vacuum.
If you do not have a good vacuum pump, you can use the following method. To protect my own butt I must mention that it is against the law to vent any refrigerant into the atmosphere intentionally… Ok, yeah and uh huh… You can “chase” the old refrigerant and air out of the system by simply charging one can worth on either the high or low side and venting (ahem, reclaiming) on the other side. Years ago this was done all the time with R12. It does not work as well as a hard vacuum for the Freons, but for the hydrocarbons it works quite well. A hard vac is still better for total evacuation.
We DO NOT charge our vehicles using the refrigerant weight formula for hydrocarbon refrigerants. It simply has never worked well for us. We charge all systems using temps and pressures. We charge the system to 50-70psi static pressure then start the engine/compressor and finish the charge with the system running at 1500-2000 rpm over the NEXT 30+ MINUTES! Hydrocarbon refrigerants are a mixture and need to be allowed equalize for a few minutes after every “squirt” into the system. In fact, after you have achieved your CORRECT pressures, you can actually see a 2-6 degree temperature drop in the overall system after the refrigerant has mixed in the system for a 24-36 hour period! We have seen this time and time again. Other than systems with dual A/C, the hardest systems to properly charge are R12 (some R134) systems on rear wheel drive vehicles that have a mechanical fan on the front of the engine.
Here is a quick note on those mechanical fans with a temperature-controlled clutch. You NEED these fans to work PERFECTLY if you want anything close to proper cooling from one of these cars. ESPECIALLY at idle and low speeds!! The temperature-controlled clutch is designed to engage the fan when the air passing over it (from the radiator!) reaches a certain temperature. If the thermostat in the cooling system of your car is even 5 degs lower in opening temperature than what the car was designed for the air passing through your radiator could take up to 10-20 minutes (or likely never) to get up to a high enough temperature to engage the fan clutch (which will then disengage after the temp has dropped again)! This is LONG past the time where your A/C vent temps have climbed above 70 degs and can take up to 6 miles of driving at 50+ mph to get the condenser to cool off again! You need a fully operational fan clutch assy and the correct thermostat in your cooling system for the A/C to operate properly. These cars also need to have the engine up to full operating temperature before you can properly charge the A/C using temps and pressures.
If you are (slowly) charging a system (at 1500-2000rpm) and have reached what you think are the correct pressures on the high and low sides, but your vent temp is still at 65+ degs, you are probably under charged. (this commonly occurs on HOT days 95+ degs) In this case, wet down both the condenser and accumulator with a garden hose and watch the pressures drop. Add another ounce of refrigerant and WAIT for the pressures to climb again. Wait until the water is all gone and the pressures have stabilized; about 6-10 mins. Repeat until the vent temp drops and the pressures are where they need to be. DO NOT OVER CHARGE! The difference between a correct charge and over/under charging seems to be about plus or minus 1.5 ounces!! (Especially as the ambient air temp rises above 95degs) This method assumes that you are being careful and SLOW and waiting for system stabilization between charges! You do not want to over charge in ANY case. The main reason is that you really cannot “purge” excess refrigerant from the system. Once again, most hydrocarbon refrigerants are mixtures and you have no way of knowing which part of the mixture you are removing from the system. If you must bleed excess from the system I would ONLY do it after the system has been running for at least 30 minutes at 2000 rpm to fully mix the parts of the refrigerant. Even so, I do not recommend it.
As for the correct pressures…that TOTALLY depends on the ambient air!!!! Typically, what you would like to see is about a continuous 21-24 psi on the low side / 95+ ambient air / 1500-3000 rpm / while the car is moving over 30 mph. The high side should likely be slightly over 190 psi in these conditions. Worry more about the low side and your vent temps. I say it this way because it is near impossible to create driving “air” conditions for the condenser while it is sitting in your driveway. Driving the car with a low charge will cool the condenser to the point (just like spraying water) where the pressures will drop and the compressor will cycle (reducing cooling) or the evaporator will freeze up. This can most commonly be observed during a road test where the vent temps are lower at 20-30 mph than at 50 mph!! A low pressure switch set too high will also cause this condition even when refrigerant charge is correct!!! Practice makes perfect in this situation. You simply need to go slow and use your gauges, thermometer and road tests.
The road test:
The drop dead best way to get a TRULY full and correct charge with ANY refrigerant is to read the gauges WHILE the car is in motion. The readings you will get will be TOTALLY different than the ones you got without the car moving. TOTALLY. (Unless you have the best condenser fan(s) ever!) Route the hoses AWAY from the throttle linkage and exhaust and then under the rear most portion of the hood where the hood gasket will not crush them, usually. Then trap the hoses and gauges under a wiper blade so that you can see them through the windshield while driving. If you are brave, route the charge hose through the driver’s window and charge as needed. With this method you will actually start to understand and be able to use the data in a temp/pressure chart!! Especially the high side pressures portion. Please be careful.
These are typical results for us in 90-92 deg ambient air: (all recirc air at max blower after 6-10 mins)
R134 system convert to ES12a with electric condenser fans>> 36-40 degs driving; 43-47 @ idle
R12 system convert to ES12a with electric condenser fans>> 38-43 degs driving; 45-50 @ idle
R12 system convert to ES12a with mechanical fan>> 40-45 degs driving; 48-58 @ idle
Someone will probably ask about dual A/C now. Well, the theory is that because of the increased thermal efficiency of the hydrocarbon refrigerant, most condensers simply get too hot, too quick when asked to handle two A/C units using a hydrocarbon refrigerant. The increased propane in the new “industrial blend” seems to have fixed this issue, but we have only tried it once so far. (worked acceptably) Note that the above method of cooling the condenser with water is HIGHLY recommended when trying to get the correct charge on ANY dual A/C system with any refrigerant.
Bottom line:
All components, lubricants, and capacities must be correct for any A/C system or refrigerant to produce low temps in 90+ deg ambient air all all rpms. This is why reputable A/C shops must fix all leaks, flush the entire system, fill with fresh and correct amount of oil, and replace any questionable parts (orifice, exp valve, accumulator) before they can expect the A/C system to work like the day it rolled off the assembly line. Otherwise, they would be burning up all their time guessing and dealing with comebacks. (not that this doesn’t happen!)
There are no short cuts with A/C repair, just skill OR luck!!!
Reply #7April 12, 2009, 07:56:00 pm
jettabrendan
  • 198
    geschwindigkeitsueberschreitung
R134 A.C. or No??
« Reply #7 on: April 12, 2009, 07:56:00 pm »
red tek worked amazingly and it was cheap.
1991 Jetta TD Dark Teal
1983 bmw e21 320is Hennarot
1997 Volvo 850 Black
Reply #8April 12, 2009, 10:35:49 pm
R134 A.C. or No??
« Reply #8 on: April 12, 2009, 10:35:49 pm »
Quote from: "jettabrendan"
good to know.  their price is about on par with duracool, and they have a similar 'kit' available at cdn tire.  what i like about their kit is that it comes with an oil tester which tells you if the oil requires changing... pretty cool!
Reply #9June 28, 2009, 08:38:17 am
calebessent
  • 16
Re: R134 A.C. or No??
« Reply #9 on: June 28, 2009, 08:38:17 am »
Dang, I need to do all that to get my Rabbit cooling? The PO had the old typical "It cools, it just needs a charge" disclaimer in his advertisement.
It doesn't look like I will be able to get it "topped off" with refrigerant and expect good results. All this mess about hard vacuum and system flushes seems like it is going to be beyond the limitations of my tool set. Has anybody had decent results doing it themselves? I'm assuming my '81 has R12 in it, right?
Reply #10June 28, 2009, 09:09:27 pm
Quantum TD
  • 1195
« Reply #10 on: June 28, 2009, 09:09:27 pm »
Relax. You've got an R-12 system. It's a whole HELL of a lot cheaper to recharge a stock R-12 system (even with a conversion to R-134) than a stock R-134 system.
The nice thing about an R-12 system is that you can actually flush the system. On R-134 systems, the parallel-flow condensers must be thrown away when you have compressor failure. With R-12 systems, just flush the system, replace the compressor, receiver-dryer and expansion valve (along with all the seals) and you're ready to go. Also, R-12 compressors for MK1 and 2 applications are cheaper too. You can use an R-12 replacement, and still get the same cooling. Or, switch to R-134 and get good good cooling with that.
All told, you can buy all new parts (compressor, receiver-dryer, expansion valve, seals) for about $300-400. Flush it and recharge for about another $100-150.
I'm looking at $1800 to have a 2001 TDI compressor replaced by a shop. If I do it myself, I might save $500.
Reply #11June 28, 2009, 11:47:44 pm
OM617
« Reply #11 on: June 28, 2009, 11:47:44 pm »
Recharging R12 is not illegal. Anyone can buy it on the open market. Pretty much anything before the mid 90's will have R12.
Reply #12July 07, 2009, 10:09:47 pm
« Reply #12 on: July 07, 2009, 10:09:47 pm »
It is illegal to recharge a car with R12 or buy it without a license. I think they can't sell new R12 either, only recycled and old stock. This is a federal law. This is regulated by the EPA and you can get certified by a trade school to use r12 legally. It's not that hard to obtain the license but would probably not be worth doing unless you plan on making income doing a/c work.
The hardware stores 1 hour to the south of me sell R12 in 1 lb cans for around $5 each and they sell the hose you need to put it in the car. This is one of the benefits of living in the "gray area" between the U.S. and Mexico. The cans I've seen there are made in the U.S.A. by DuPont. I guess they can manufacture it here but for export only.
Reply #13July 07, 2009, 10:30:53 pm
maxfax
  • 2126
« Reply #13 on: July 07, 2009, 10:30:53 pm »
I believe you are also supposed to have proof of some method of recovery for R12 before they can sell it to you... I rmeber somethign about that when I got my license..    I don;t know about now, but it used to be real easy to get the cert..    MACS I think it was would send you a booklet.. Read the book, fill out the test, mail it in with $12 and they sent you a certificate...
Reply #14July 08, 2009, 03:15:32 am
OM617
« Reply #14 on: July 08, 2009, 03:15:32 am »
It is nothing more than a formality. The test costs $15 and is open book, you can even do it at home and mail it in.
You can even buy R12 on eBay.
http://motors.shop.ebay.com/__?_from=R40&_trksid=p3841.m39.l1313&_nkw=r12&_sacat=
