Author Topic: aaz into a mk1 cabrio build  (Read 74135 times)
Reply #15October 15, 2007, 11:04:16 am
blkboostedtruck
  • 1535
« Reply #15 on: October 15, 2007, 11:04:16 am »
where did you find the EGT gage? I like that one! how much is that one?
thanks Duane
'66 variant 1500S
'81 caddy 1.9 turbo diesel
'82 caddy gas 1.8 G60
 3 jettas '82' '04 '14TDI
Reply #16October 15, 2007, 11:43:54 am
giulianot
  • 146
« Reply #16 on: October 15, 2007, 11:43:54 am »
The  EGT gauge is a glow shift and it was $115 cn  and it was on ebay. It reacts to heat very quickly and looks cool, so i went with it.
1990 cabriolet 1.9 aaz, kkk 24/26,  Giles pump, big  2.5" intercooler,  3 " P.P. downpipe
Reply #17October 17, 2007, 06:54:26 am
giulianot
  • 146
« Reply #17 on: October 17, 2007, 06:54:26 am »
Does anyone know where i can by a new rad fan shroud for the mk1's? mine is so rotted that its beyond sandblasting and paint
Reply #18October 22, 2007, 07:30:21 am
giulianot
  • 146
« Reply #18 on: October 22, 2007, 07:30:21 am »
I made some progress on the cabby biuld. I painted the rad fan shroud, put a new rad in , new overflow bottle, new coolant hoses, and installed the battery.  heres some pics
Reply #19October 22, 2007, 05:04:41 pm
blkboostedtruck
  • 1535
« Reply #19 on: October 22, 2007, 05:04:41 pm »
Quote from: "giulianot"
 I have some good fan shrouds! where exactly are you located?
thanks Duane
'66 variant 1500S
Reply #20October 24, 2007, 05:09:35 am
giulianot
  • 146
« Reply #20 on: October 24, 2007, 05:09:35 am »
Thanks anyways but i got one in for now
Reply #21October 25, 2007, 05:36:58 pm
tSoG-84bit
  • 188
« Reply #21 on: October 25, 2007, 05:36:58 pm »
Does the AAZ mate up to a mk1 clutch and tranny? I need a new engine, figured I might as well go all out, but plan on staying all mechanical (no tdi)
I've tried searching, and your swap is definitely the closest I can find to what I am looking for.
Any Info you are willing to share on this swap is greatly appreciated.
Thanks,
tSoG.
84bit 1.6na
Engine died, pulling it apart, putting something new in it's place.
Reply #22October 25, 2007, 08:50:09 pm
spencebm
  • 686
« Reply #22 on: October 25, 2007, 08:50:09 pm »
my older bro is putting a 1.8 16v in his cabby... :(  i wish i had a real bro...
Ben Spencer
Reply #23October 26, 2007, 06:22:03 am
giulianot
  • 146
« Reply #23 on: October 26, 2007, 06:22:03 am »
Quote from: "tSoG-84bit"
Thanks,
tSoG.
Yes the aaz engine will mate to many different clutch combinations it all depend on what trany you will be running, is it an 020, does it have a big spine or a small spline, do you have a 210mm flywheel? my setup is an old 020 trany small spline so i went with a 87 rocco 16v gasser clutch and flywheel and that seems to be holding for now .well see what happens when the motor get broken in and i start to push high levels of boost.
Reply #24October 26, 2007, 06:23:44 am
giulianot
  • 146
« Reply #24 on: October 26, 2007, 06:23:44 am »
Quote from: "spencebm"
Convince him that hes making a big mistake going with a garbage gasser, or wait till hes done the swap, then smoke him in your diesel! :D
Reply #25October 26, 2007, 06:28:40 am
giulianot
  • 146
« Reply #25 on: October 26, 2007, 06:28:40 am »
My new intake runner make to accept 2.5" piping :D
Reply #26October 26, 2007, 08:52:26 am
spencebm
  • 686
« Reply #26 on: October 26, 2007, 08:52:26 am »
haha, yeah it will happen, this thing is going to be a monster!  what kind of tranny are you running?  make sure and get a tall 5th gear and go really fast!
Ben Spencer
Reply #27October 26, 2007, 08:58:05 am
giulianot
  • 146
« Reply #27 on: October 26, 2007, 08:58:05 am »
Thanks, i cant wait to see how fast this car is really going to be.  The trany is an ACN with a very tall .69  fifth gear in it, im guesing 240kph @ 4500rpm :D  :
Reply #28October 29, 2007, 01:08:21 pm
935racer
« Reply #28 on: October 29, 2007, 01:08:21 pm »
Just finished welding up this custom unit for you this morning:
Reply #29October 29, 2007, 02:25:42 pm
« Reply #29 on: October 29, 2007, 02:25:42 pm »
Quote from: "935racer"
SHAAWING!!!!!!!!   :D
