Author Topic: need help finding right speedo cable for my rabbit w/ahu/02a  (Read 7556 times)
October 02, 2007, 02:45:44 pm
estimatd
  • 40
« on: October 02, 2007, 02:45:44 pm »
Hello, I recently had an AHU with an 02A tranny swapped into my Caddy and I am really not sure what to do for a speedo cable.  I've heard that the early Corrado G60 cable works for a mk2, will it work in a mk1 instrument cluster as well?  Thanks in advance.
-Charlie
Reply #1October 02, 2007, 03:17:27 pm
BlackTieTD
  • 1512
« Reply #1 on: October 02, 2007, 03:17:27 pm »
i think corrado/mkII has a retaining clip to hold the cable to the speedo, while mkI is screw-on. afaik..
i'm sure it could be adapted
Reply #2October 02, 2007, 03:23:12 pm
estimatd
  • 40
« Reply #2 on: October 02, 2007, 03:23:12 pm »
just meaning that I would need to find an alternate way to hold the cable in place?  thanks.
-Charlie
Reply #3October 02, 2007, 03:28:52 pm
estimatd
  • 40
« Reply #3 on: October 02, 2007, 03:28:52 pm »
is there a more suitable cable for this setup?
Reply #4November 04, 2007, 06:59:47 am
mk2tdi
  • 17
« Reply #4 on: November 04, 2007, 06:59:47 am »
any mk2 1.3 ones will fit
5dr Syncro, AHU 1.9TDi, .216 Nozzles, Tuning Box, 3" Downpipe, FMIC, De-Cat, Just needs all putting together!
Reply #5November 04, 2007, 08:20:12 am
MJF
  • 581
« Reply #5 on: November 04, 2007, 08:20:12 am »
Quote from: "mk2tdi"
But isnīt mk2 speedo with clip on? I have mk1 Passat cable, itīll fit directly.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #6November 04, 2007, 09:32:40 am
mk2tdi
  • 17
« Reply #6 on: November 04, 2007, 09:32:40 am »
Quote from: "MJF"
it clips into the back of the clocks as its the same for mk1 and mk2 golfs and screws into the speedo drive on the gearbox
Reply #7November 04, 2007, 09:47:03 am
MJF
  • 581
« Reply #7 on: November 04, 2007, 09:47:03 am »
My mk1:s had screw in speedos, not clips.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #8November 04, 2007, 11:29:56 am
mk2tdi
  • 17
« Reply #8 on: November 04, 2007, 11:29:56 am »
maybe there different to the uk version?
Reply #9November 04, 2007, 03:07:05 pm
estimatd
  • 40
« Reply #9 on: November 04, 2007, 03:07:05 pm »
yeah, mine screws in as well, it probably is different in the UK then.......
for future reference of anyone attempting the same, I posted this question on the vortex and the answer can be found here http://forums.vwvortex.com/zerothread?id=3472903 or do a search for Shawn B on the vortex and follow his build up, the info is on pg. 13.
"The piece that comes off from the Rabbit cable is the aluminum threaded collar that turns onto the Rabbit speedometer. I believe bajaguy carefully cut the end off where it was crimped on using a air cut off wheel or a cut off wheel on the grinder (you get the idea, carefully cut it off then clean up the hole to put it back on the O2A cable. Same idea with the O2A cable but this one is plastic, carefully cut /remove the plastic end that connects to the speedometer not pulling the inner steal sheathing around the inner square cable apart. Then carefully crimp the rabbit end onto the O2A cable end."
Reply #10November 05, 2007, 07:05:24 am
MJF
  • 581
« Reply #10 on: November 05, 2007, 07:05:24 am »
Yep, Passat cable is just like that.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #11November 05, 2007, 07:39:56 pm
estimatd
  • 40
« Reply #11 on: November 05, 2007, 07:39:56 pm »
so you're saying that there is a Passat cable that would screw on just like my Rabbit?
