timing woes/ need help
Pages:
Topic: timing woes/ need help (Read 6149 times)
Reply #15
October 02, 2007, 03:30:41 am
Mark(The Miser)UK
Reply #15 on:
October 02, 2007, 03:30:41 am »
Quote from: "turbosuzi"
Did the diesel pulse coincide with the compression stroke @ #1?
How could I check that
Rocker cover off, ignition on, but GP's off Hand crank or brief use of starter to see pulse[dribble] of diesel from loosened fuel line @#1 injector [raise line slightly].It should coincide when cam lobes are pointing up like rabbits ears...
:idea:
What do you think that you've done to the pump other than install it to cause any damage??
Mark-The-Miser-UK
Reply #16
October 03, 2007, 07:33:09 am
turbosuzi
Reply #16 on:
October 03, 2007, 07:33:09 am »
I haveent done any tihng to the pump yet. I have no idea what would cause it to feel like it has no throttle.
Reply #17
October 03, 2007, 08:32:49 am
Reply #17 on:
October 03, 2007, 08:32:49 am »
It really really is sounding like you got a bum pump from eBay... or have you swapped back to the old pump ??
Lack of throttle can be a couple of things internally... most likely a disconnected/broken governor spring assembly.
Reply #18
October 04, 2007, 09:20:18 am
turbosuzi
Reply #18 on:
October 04, 2007, 09:20:18 am »
I will be installing the old pump tomorrow and I will let you know what happens.
Reply #19
October 07, 2007, 10:17:40 am
turbosuzi
Reply #19 on:
October 07, 2007, 10:17:40 am »
OK I resealed the old pump and reinstalled it. It is running but now I have alot of unburned fuel on start up and I have to crank a good 20 sec to get it started. It will intermittenly fire then die then it will start after 4-5 times of this. then it will idle hard until it warms up. It also runs hotter now. I advanced the timing to 1mm could this have anything to do with the hard start? I am going to turn the timing back to see if that helps. I was wondering if maby injectors might clogged from something when I had it open. is there a way of checking them?
Reply #20
October 07, 2007, 11:17:05 am
Reply #20 on:
October 07, 2007, 11:17:05 am »
advancing the timing should help with a cold start. it allows the diesel more time to burn, but too advanced, and you could burn up some internal components such as the piston tops (because the burning diesel lingers in there)
Reply #21
October 07, 2007, 04:13:04 pm
turbosuzi
Reply #21 on:
October 07, 2007, 04:13:04 pm »
fuel filter is about 1 1/2 yrs old. The diesel is in a suzuki samurai and I dont have a cold start hooked up, which direction should the lever be up or down? I insatlled new glow plugs.
Reply #22
October 07, 2007, 04:16:06 pm
turbosuzi
Reply #22 on:
October 07, 2007, 04:16:06 pm »
After it is started and warm it idles fine and I drove it about 30 miles stopped a couple of times. the longest stop was about 4hrs and it stillstarted hard so I dont think there is any air in the lines.
Reply #23
October 07, 2007, 07:27:15 pm
turbosuzi
Reply #23 on:
October 07, 2007, 07:27:15 pm »
OK I had the cold start away from the sproket while I did the timing. I will correct that and let you know. I dont have a clear tube feeding the pump but I will put one tomorrow. Thankyou for all of your help.
Reply #24
October 07, 2007, 10:11:33 pm
turbosuzi
Reply #24 on:
October 07, 2007, 10:11:33 pm »
It seems that the cold start was the problem but I wont know until tomorrow for sure. Thank you all for all of your excellent help!!
Pages:
