Author Topic: Black smoke under load  (Read 2326 times)
September 26, 2007, 02:09:52 pm
gamber
  • 23
« on: September 26, 2007, 02:09:52 pm »
I just posted some information on smoke color, now I need some assistance in troubleshooting my IDI
First the link: http://www.vwdiesel.net/phpBB/viewtopic.php?t=10578
My high KM IDI (1400 km per week!) has recently started to smoke under load.  The color is black, so I am assuming it is getting too much fuel.  Any ideas where to start here?
   - increase the boost?
   - decrease the max fuel screw?
   - decrease the enrichment?
   - is it an air leak?
Thanks!
Reply #1September 26, 2007, 08:04:00 pm
Black Smokin' Diesel
  • 656
« Reply #1 on: September 26, 2007, 08:04:00 pm »
First check the air filter to see if it's clean. Then I'd check the boost pressure to make sure it's ok. The diverter valve may be broken and dumping all the pressure out (try to block it to see if it helps).
Reply #2September 26, 2007, 10:36:21 pm
rob76
  • 69
« Reply #2 on: September 26, 2007, 10:36:21 pm »
Every older diesel I see on the road makes black smoke under acceleration. Ever dump truck and school bus too. Unless it's pumping out huge clouds of it I wouldn't worry too much.  But then again I'm no expert.
'91 Jetta Turbo Diesel.
Reply #3September 26, 2007, 10:56:41 pm
Op-Ivy
  • 513
« Reply #3 on: September 26, 2007, 10:56:41 pm »
Quote from: "Black Smokin' Diesel"
I second the air filter idea.
Also, do you run any additives? Plugged up or worn injectors can cause unburnt fuel.
Matt
