Author Topic: needed, non a/c alt bracket for 91 eco jetta.  (Read 4703 times)
September 18, 2007, 07:55:40 pm
trent77
  • 217
« on: September 18, 2007, 07:55:40 pm »
As the title states. I need the brackets for a non a/c 1.6 turbo. if you can help that would be great. I am in wisconsin, so if you are close it would be even greater. thanks
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1September 18, 2007, 09:13:00 pm
« Reply #1 on: September 18, 2007, 09:13:00 pm »
I have them, but they should be the same as the AC ones
Reply #2September 19, 2007, 11:55:19 pm
  • 2932
« Reply #2 on: September 19, 2007, 11:55:19 pm »
Yep, same bracket AC or not.
Reply #3September 20, 2007, 04:12:37 pm
trent77
  • 217
« Reply #3 on: September 20, 2007, 04:12:37 pm »
It is the same? Do I have to move the alt to the a/c location? If I install the alt in the same location as it was with the a/c installed, there is no way to drive it. It is driven off of the a/c. thanks for any input.
77 westfalia
06 GMC Duramax
Reply #4September 20, 2007, 07:14:15 pm
trent77
  • 217
« Reply #4 on: September 20, 2007, 07:14:15 pm »
If I mount my alternator in it's usual position, does it get a different pulley? one with more offset? Also if I do that, does the idler pulley get offset also? And what is the deal with the free wheeling pulley on the waterpump? I'm on a learning curve with my VW right now, It Is my first older watercooled in awhile. thanks
77 westfalia
06 GMC Duramax
Reply #5September 21, 2007, 02:20:01 am
  • 2932
« Reply #5 on: September 21, 2007, 02:20:01 am »
If you are trying to go non-AC.
 Same bracket, normally a different, 65 amp alternator.
 I have a post over on vwdieselparts.com that shows how I converted my '85 TD engine (in a '91 Golf) to non-AC. It also has pics of some of the different alternator setups.
 Search under fatmobile, in the general fora.
Reply #6September 21, 2007, 06:06:34 am
myke_w
  • 1099
