Author Topic: boost controller problem or?  (Read 2006 times)
September 16, 2007, 04:26:17 am
Demons UK
  • 21
« on: September 16, 2007, 04:26:17 am »
just fitted a boost controller but it seems to be 'dumping' alot of boost when i change, actually sounds like a dump vavle almost?
is this normal?
i've got the stick bov and wastegate so i think that might be why, its on a gtd 1.6
Reply #1September 16, 2007, 07:03:11 am
subsonic
  • 1836
« Reply #1 on: September 16, 2007, 07:03:11 am »
What do you have it set / regulated too?  Perhaps it is doing it's job and dumping out the wastgate?  In your post do you mean that you have disabled your wastegate?
Reply #2September 16, 2007, 08:40:14 am
Demons UK
  • 21
« Reply #2 on: September 16, 2007, 08:40:14 am »
I haven't touched the wastegate or BOV, so there blowing all my boost away at around 12psi?
Getting the boost controller tomorrow so will find out what i already know i expect, although the controller is set to ~15psi
any links/tips on how to remove the Waste gate or BOV?
and also should i increase my max fuel when i see what PSI I'm running at, the car doesn't seem to be smoking black at all when i rev now, if anything its blue/white =/
Reply #3September 16, 2007, 10:27:22 am
« Reply #3 on: September 16, 2007, 10:27:22 am »
Yes, the stock BOV will go at 12 psi... if you search here and at www.vwdieselparts.com you will find discussions *and* pictures of various ways to defeat this valve.
