Author Topic: tapping noise after warm up...90 TD Jetta  (Read 2145 times)
September 15, 2007, 06:59:39 pm
madmedix
  • 204
« on: September 15, 2007, 06:59:39 pm »
OK. Got this girl on the road, but....after a say, 80km ride on the freeway or even a mix of highway/street/freeway (about 100km/h etc) I'll be sitting at the stoplight near home and I can hear a clacking and it changes with RPM. (Sounds like it's coming from the valve train but I'll use a stethoscope to narrow it down). Not present when cold started. Just to throw a wrench into the story, I drove her today for a good mix of town/highway for about 50 km. and not a sound. She's otherwise fine. I've put 3500 km on her lately and averaging 960km per tank of petrodiesel.
Wondering if this is a lube issue (maybe need a better oil pump?) from the oil thinning out after a long run (I use good oil & I let her cool after a run so the turbine doesn't coke up) or not enough pressure to lube the top end? . I would like to put in an oil pressure guage but not sure which of the two senders I should tee out. Finding conflicting posts during a search of this site and the "other" one  :lol: . I'm running GTX 15w40 (Synthetic isn't really an option right now). What's all this I'm seeing about a 32mm oil pump and would that fit my sweetie? Or am I getting tunnel vision and should be looking for something else? (btw, she's got 370k on the clock)
Cheers,
Andy
'90 TD Jetta
Reply #1September 18, 2007, 05:19:16 pm
madmedix
  • 204
« Reply #1 on: September 18, 2007, 05:19:16 pm »
bump!
'90 TD Jetta
Reply #2September 18, 2007, 05:21:07 pm
bevboyy
  • 200
« Reply #2 on: September 18, 2007, 05:21:07 pm »
Run some diesel purge in it and get back to us.
1987 Jetta Mk2 - daily driver, MZ 1.8 goodness. TJ auto trans..
Gone but not forgotten:
1985 Mercedes 300d Turbo
1987 Olds Delta 88 Royal Brougham
1992 Mercedes 190e 2.3
1984 Mercedes 190e
1983 Quantum TD
1992 Jetta TD
1983 BMW 533i
1982 BMW 320iS
1979 Mercedes 300D (non turbo)
1977 BMW
Reply #3September 23, 2007, 09:14:25 am
madmedix
  • 204
« Reply #3 on: September 23, 2007, 09:14:25 am »
As in seafoam? I'll do that as soon as I fix the brake line that ruptured yesterday :-( Might as well do 'em all at the same time.
'90 TD Jetta
