Author Topic: boost controller ?  (Read 3191 times)
September 14, 2007, 02:40:21 pm
ELVIS
  • 51
boost controller ?
« on: September 14, 2007, 02:40:21 pm »
got an engine as a 'cut out' from the breakers - i think the hose that has been cut is meant to go to the factory boost controller . unfortunately i never had it from the car before it was crushed . do i need one on a near enough stock engine ? can i get away with plugging it ? any ideas ? am i best to get another factory boost controller from a wrecker ?  cheers   elvis
Reply #1September 15, 2007, 01:28:41 pm
Hillshy
  • 103
    • http://www.hillshy.co.uk
boost controller ?
« Reply #1 on: September 15, 2007, 01:28:41 pm »
hey elvis,
is that you?......... from brickyard?
hello, id rejoin it with a jub clip it won't hurt it and will seal well, even if you run 15psi i won't pop off.
hills
Hillshy T25 caravelle "Hilli" currently thrashing 1.6 td GTD engine
NOT SO FRIGGEN HILLSHY ANYMORE!
15psi of BOOST set my c'velle free
Reply #2September 15, 2007, 01:52:08 pm
ELVIS
  • 51
boost controller ?
« Reply #2 on: September 15, 2007, 01:52:08 pm »
'tis me ! :lol:   i dont understand your answer - am i a mong ? rejoin it to what ? can i just put a piece of tube on and block the end with an M4 bolt and jubilee clip it shut/blank it off ? cheers  elvis
Reply #3September 15, 2007, 01:59:32 pm
Hillshy
  • 103
boost controller ?
« Reply #3 on: September 15, 2007, 01:59:32 pm »
fort it was you :o
"standard boost controller" i took that to mean the bov valve under your finger, (pic is a bit fuzzy) but it looks like the black hose is split.
is that what you mean or is that not the case?
hills
Reply #4September 24, 2007, 05:40:18 am
clanton1.8T
  • 6
boost controller ?
« Reply #4 on: September 24, 2007, 05:40:18 am »
:shock: the only hose i see cut is the air intake. if thats the case if you can't block that off. get or make a new hose to run to an air filter.
Reply #5September 24, 2007, 10:35:53 am
boost controller ?
« Reply #5 on: September 24, 2007, 10:35:53 am »
Is that a T3 turbo?
maybe one of these pictures of one of my old turbos will help you
Reply #6September 24, 2007, 12:42:55 pm
ELVIS
  • 51
boost controller ?
« Reply #6 on: September 24, 2007, 12:42:55 pm »
its an AAZ , im fitting it in my T3 but using all the AAZ manifolds!
   on the second pic down , where does the braded small bore line connect to that goes from the turbo ?   cheers   elvis
Reply #7September 24, 2007, 12:45:02 pm
ELVIS
  • 51
boost controller ?
« Reply #7 on: September 24, 2007, 12:45:02 pm »
oh ,  :lol: , T3 - get it now - either T3 or K14  - cant remember without looking - ive got so much crap in my garage ive lost count :lol:
Reply #8September 24, 2007, 03:33:12 pm
boost controller ?
« Reply #8 on: September 24, 2007, 03:33:12 pm »
Quote from: "ELVIS"
That's why I added in "turbo" I knew it would throw some people off. :P
I forget where that line goes, I'm sure someone will know though
